Ressort hyper pro xtz 750 Emptypar SuperTiti Hier à 21:40
Ressort hyper pro xtz 750 Emptypar Joe644 Hier à 18:56
Ressort hyper pro xtz 750 Emptypar yop1025 Hier à 13:10
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Ressort hyper pro xtz 750 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Ressort hyper pro xtz 750 Emptypar Arni Dim 17 Nov 2024 - 14:06
Ressort hyper pro xtz 750 Emptypar Arni Dim 17 Nov 2024 - 13:13
Ressort hyper pro xtz 750 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Ressort hyper pro xtz 750 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Ressort hyper pro xtz 750 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Ressort hyper pro xtz 750 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Ressort hyper pro xtz 750 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Ressort hyper pro xtz 750 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Ressort hyper pro xtz 750 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Ressort hyper pro xtz 750 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Ressort hyper pro xtz 750 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Ressort hyper pro xtz 750 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Ressort hyper pro xtz 750 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Ressort hyper pro xtz 750 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Ressort hyper pro xtz 750 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Ressort hyper pro xtz 750 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
chaine suis fourche feux garde synchro longues huile crash reglage arrière selle vidange phare rabaissement tuto pneus embrayage galére amortisseur tenere manuel filtre essence boue réservoir
-25%
749.99 € 999.99 €
Dosrider
Dosrider
Moto : Xtz 750
Kms de ma moto : 64000
Ville ou région : Bordeaux
MessageSujet: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 15:39
Bonjour, je post un message car après plusieurs recherches je n'ai pas trouvé m'a réponse. J'ai commandé mets ressort progressif mais avant de les monter je voulais avoir confirmation des experts
Faut il simplement remplacer les ressorts d'origine par les progressif ou enlever une cale quand on mets les hyper pro?
La viscosité 15 et 20 est elle très différente ? Car j'ai la 20 avec le kit ? Le comportement va-t-il être radicalement changer ?
Merci pour les infos,
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 18:30
Change simplement tes ressors (pas de cales) vidange l'huile de fourche avec de la 15 et youpi !
Meilleur tenue de route , plongeon de la fouche nettement freiné (progressivement) enfin que du mieux bien
Ressort hyper pro xtz 750 Ct2rou14Ressort hyper pro xtz 750 Logo_y12Ressort hyper pro xtz 750 Vosges11 Ressort hyper pro xtz 750 J_y_yt11  Ressort hyper pro xtz 750 J_y_yt10
Dosrider
Dosrider
Moto : Xtz 750
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 18:34
Merci, c super. Je suis rassuré. Y a plus qu'à.
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 18:42
Penses a monter du pneu de bonne qualité (genre TR 91 etc ..) car si pas avec la confiance tu risque d'aller au tas ! ;)
https://nsm08.casimages.com/img/2016/10/28//16102810584511968614587896.jpg
Dosrider
Dosrider
Moto : Xtz 750
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 19:51
Je m'oriente sur du off road. Est-ce que sa ira avec cette monte ?
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyVen 28 Oct 2016 - 20:11
Tout dépend de ton idée ou de ton sens du Off road ?
A chaque monte son style de terrain !
Dosrider
Dosrider
Moto : Xtz 750
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyDim 4 Déc 2016 - 15:40
Salut la compagnie, bon j'y suis, j'ai changé mes ressort avec tous les joints. J'ai mis de l'hyper pro. Par contre pas encore de test routier, il me reste une synchronisation à faire avant. En regardant de plus près les ressorts d'origine font pratiquement la même longueur que les hyper pro. J'ai pas remis le cylindre creux d'origine, vous me confirmer car du coup j'ai pas forcé pour remettre le bouchon et sa me paraît bizarre ?? Dois-je le remettre ? Désolé je suis novice.
gazzz
gazzz
Kms de ma moto : 39000
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyDim 4 Déc 2016 - 19:05
oui bizare tes ressorts en place ,il doivent sortir de 2 ou 3 cm comme ceux d"origine cales comprise
Ressort hyper pro xtz 750 Images19Ressort hyper pro xtz 750 P1010412Ressort hyper pro xtz 750 10406711Ressort hyper pro xtz 750 11255410Ressort hyper pro xtz 750 17021910
Ressort hyper pro xtz 750 Logo1010Ressort hyper pro xtz 750 Sans_t10
Dosrider
Dosrider
Moto : Xtz 750
MessageSujet: Re: Ressort hyper pro xtz 750   Ressort hyper pro xtz 750 EmptyDim 4 Déc 2016 - 20:07
Oui en effet. Je viens de regarder la notice et c'est bien l'entretoise à mettre en dernier. Donc si je mets le ressort, je tire sur le tube supérieur pour l'étendre au max, le ressort disparaît. Je pense que je vais remettre l'entretoise, cylindre creux. Si quelqu'un peut me confirmer. Merci
» Ressort de fourche
» Hyper Ténéré 850
» Modèle d'études Yamaha "Hyper Ténéré" 1988
» ressort de fourche
