Bagagerie Shad SH 43 XTZE Emptypar SuperTiti Hier à 21:40
Bagagerie Shad SH 43 XTZE Emptypar Joe644 Hier à 18:56
Bagagerie Shad SH 43 XTZE Emptypar yop1025 Hier à 13:10
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Bagagerie Shad SH 43 XTZE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Bagagerie Shad SH 43 XTZE Emptypar Arni Dim 17 Nov 2024 - 14:06
Bagagerie Shad SH 43 XTZE Emptypar Arni Dim 17 Nov 2024 - 13:13
Bagagerie Shad SH 43 XTZE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Bagagerie Shad SH 43 XTZE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Bagagerie Shad SH 43 XTZE Emptypar Fredard Sam 16 Nov 2024 - 9:43
Bagagerie Shad SH 43 XTZE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Bagagerie Shad SH 43 XTZE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Bagagerie Shad SH 43 XTZE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Bagagerie Shad SH 43 XTZE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Bagagerie Shad SH 43 XTZE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Bagagerie Shad SH 43 XTZE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Bagagerie Shad SH 43 XTZE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Bagagerie Shad SH 43 XTZE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Bagagerie Shad SH 43 XTZE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Bagagerie Shad SH 43 XTZE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
embrayage filtre boue essence garde galére synchro crash manuel amortisseur huile feux vidange arrière rabaissement fourche tenere chaine réservoir pneus selle phare tuto suis longues reglage
RemRem
RemRem
Moto : Yamaha Super Tenere XT ZE Blu
Kms de ma moto : 10200
Pneu AV/AR : Bridg Battlax A40
Ville ou région : Languedoc Roussillon
MessageSujet: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 5 Nov 2015 - 10:35
Voila que depuis quelques temps je cherche une bagagerie pour ma ZE ( Pour le moment aucun problème ), le soucis c'est que je possède déjà un top case SHAD et je voudrais donc des valises SHAD ( Oui je suis casse bonbon Smile ).
En faisant le tour sur le net je suis tombé sur les valises SH 43 SHAD ( Possibilité de mettre deux casques intégraux dans chaque valise ).
Voici les valises :
Sur Ixtem Moto la paire de valises est à 297.00€.
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE C_200011" />
Les valises trouvé manque le support, la belle surprise c'est que SHAD ne fait pas de support pour la XTZ embarrassé .
Je me suis donc tourné vers SW-Motech et j'ai trouvé ça :
Le support est à 219.95€ sur Ixtem Moto.
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Z1217510" />
Avec il faut un kit adaptateur SHAD :
39.95€ sur Ixtem Moto.
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Z1081310" />
Et pour pouvoir sécuriser le tout :
39.95€ toujours chez Ixtem Moto.
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Z1125410" />
Pour un total de 596.85€ - les 8% que j'ai par rapport au forum Fz cela me fait 549.10€.
J'aurais voulu avoir quelques avis par rapport à cette configuration. Est ce que quelqu'un a déjà vue cette config sur une XTZE ?
Merci d'avance pour vos réponses !! Double V
Bagagerie Shad SH 43 XTZE 2dt39s9
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 5 Nov 2015 - 10:58
Salut,j'ai ce type de support avec le kit d'adaptation pour monter des valises givi,aucun soucis les supports sont de bonne fabrication,par contre les serrures antivol sont un peu legere et a mon avis faut pas s'en servir tout les 5 mns sinon elle risque de foirer,elle etait sur ma moto a l'achat,je demonte jamais mes supports
Il me semble qu'il existe chez Sw-motech des kits support non demontable rapidement et ça coute moins cher que ceux avec demontage rapide,par contre est ce que ça existe pour la 1200 interrogation interrogation
Salut Michel
Bagagerie Shad SH 43 XTZE 8490181200XTZ1
Bagagerie Shad SH 43 XTZE 229534038Bagagerie Shad SH 43 XTZE 7568070011Bagagerie Shad SH 43 XTZE 150151029Bagagerie Shad SH 43 XTZE 457366023Bagagerie Shad SH 43 XTZE 555053040
MES ALBUMS PHOTOS et MON BLOG
RemRem
RemRem
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 5 Nov 2015 - 11:32
Pour le kit support non démontable j'ai rien vue sur le site Motech pour la 1200, pour le support je suis comme toi Michel j'évite de démonter les supports d'où le fait que je prenne le kit serrures. Une fois posé j'y touche plus ! Smile .
Par rapport au support j'ai regardé la notice de montage ( Rien de bien dur j'avais le même système sur ma deuxième DL 650 ). La seule chose qui me "perturbe" c'est la pièce qui viens ce fixer a l'endroit même ou la plaque d'immatriculation est placé pour pouvoir relié les deux supports valises ensemble.
Voici la notice :
http://shop.sw-motech.com/cosmoshop/artikelpdf/kft_06_145_20002_b.pdf
C'est la pièce numéro 15 sur ma DL cette pièce ( Si je me souviens bien ) était devant le support de plaque.
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 5 Nov 2015 - 14:58
Salut,sur la 1200 elle est entre la plaque et la bavette on ne la voit pas beaucoup
Si tu me donne un numero de portable en MP je t'envoie des photos
Salut Michel
RemRem
RemRem
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyVen 6 Nov 2015 - 15:52
J'ai passé commander hier pour l'ensemble que je devrais recevoir semaine prochaine. Je mettrais quelques photos des différentes étapes du montage pour que cela puisse aider d'autres personne en cas. Michel je te remercie pour ton retour d'expérience !
RemRem
RemRem
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyLun 16 Nov 2015 - 12:00
J'ai reçu mes valises samedi dernier le (14 novembre) montage en suivant puis test le dimanche lors d'une balade.
Je suis satisfait du résultat les valises sont suffisament grandes pour accueillir un sac + petites babioles, la fixation intérieur de la valise bloque bien le contenu pour que rien ne bouge.
Je vais poster quelques photos ce soir pour montrer le rendu final.
En tout cas je suis satisfait de mon achat et du prix aussi ( 550€ livré ) je trouve cela raisonnable.
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyLun 16 Nov 2015 - 14:27
j'ai du SW motech :
je l'ai monté moi même .
pour la barre derrière la plaque , je l'ai rivetée (parce que c'est légal !)
et je l'ai aussi boulonnée pour la rigidité et le poids .
comme j'étais à St étienne où ils sont forts en visserie , j'ai acheté des boulons bombés à six pans creux et je les ai peints en blancs pour qu'ils ressemblent à des rivets clin d\'oeil
Bagagerie Shad SH 43 XTZE Dsc00811Bagagerie Shad SH 43 XTZE Dsc01224Bagagerie Shad SH 43 XTZE Dsc_0617Bagagerie Shad SH 43 XTZE Nkp11Bagagerie Shad SH 43 XTZE Dsc_1619
RemRem
RemRem
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyMar 17 Nov 2015 - 18:16
Donc voila pour les photos :
Vue de coté :
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Img_2010" />
Vue de demi-face Bagagerie Shad SH 43 XTZE 80767 .
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Img_2011" />
Vue de derrière :
Bagagerie Shad SH 43 XTZE <a href=Bagagerie Shad SH 43 XTZE Image_10" />
Je prendrais une photo pour la fixation de la plaque d'immatriculation car avec mon père ont à fait une pièce a part qui isole la pièce du support et la plaque.
gibaudan
gibaudan
Kms de ma moto : neuve
Ville ou région : rhone
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyMer 3 Fév 2016 - 18:31
SALUT A TOUS
J ai le meme probleme que t avais j ai 2 vieilles valise SHAD
Je trouve pas la refence des valises
Le KIT fixation que t as achete est il compatible a toutes les valises SHAD
RemRem
RemRem
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 4 Fév 2016 - 8:06
Pour mon kit adaptateur il est compatible uniquement avec les Valises Shad SH 42 et 43 vu sur le site Ixtem Moto.
http://ixtem-moto.com/Kit-d-adaptateur-SW-Motech-QUICK-LOCK-EVO-pour-valises-Shad_p108130.html
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 4 Fév 2016 - 16:00
Salut,c'est franchement bien ces supports motech avec possibilité d'adapter plusieurs marques de valises differente
Michel
gibaudan
gibaudan
MessageSujet: Re: Bagagerie Shad SH 43 XTZE   Bagagerie Shad SH 43 XTZE EmptyJeu 4 Fév 2016 - 17:38
BONJOUR
Je trouve pas la reference de la valise est elle notee dedans
MERCI
» Valises Givi et Top-case Shad
» support top case shad (merci de votre aide)
» Nouveau top case shad .
» PORTE VALISE SHAD
» Bagagerie Alu SW Motech
