POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar SuperTiti Hier à 21:40
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar Joe644 Hier à 18:56
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar yop1025 Hier à 13:10
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 19 Nov 2024 - 10:58
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 19 Nov 2024 - 10:49
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 19 Nov 2024 - 10:46
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 19 Nov 2024 - 10:44
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar jackal74 Lun 18 Nov 2024 - 11:58
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar Arni Dim 17 Nov 2024 - 14:06
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar Arni Dim 17 Nov 2024 - 13:13
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar yop1025 Sam 16 Nov 2024 - 23:12
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar Fredard Sam 16 Nov 2024 - 9:43
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar J-Marc Mar 12 Nov 2024 - 12:44
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar J-Marc Lun 11 Nov 2024 - 21:58
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar thierry83 Dim 10 Nov 2024 - 9:29
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Ven 8 Nov 2024 - 16:55
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 29 Oct 2024 - 20:18
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar REYNALD Mar 29 Oct 2024 - 20:00
POSE D UN VOLTMETRE PERMANENT ET CONSO Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
arrière embrayage selle réservoir suis feux reglage huile amortisseur fourche tuto crash boue vidange galére longues essence synchro tenere garde rabaissement manuel phare filtre pneus chaine
-28%
229.99 € 318.99 €
piolan04
piolan04
Moto : XTZ 750 SUPERTENERE ET JE NE SAIS PAS QUOI PRENDRE EN PLUS
Kms de ma moto : 97000
Pneu AV/AR : dunlop trailmax
Ville ou région : VAR
MessageSujet: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptySam 9 Jan 2016 - 19:45
Y a quelques année, j'ai posé un voltmètre de ce type
POSE D UN VOLTMETRE PERMANENT ET CONSO Tumbleton-and-twist-voltmetre-tp_3079949326329740956vb
Peur de la conso en branchement direct sur la batterie, je l'ai branché en parallèle aux veilleuse ou  à la place de la veilleuse (m'en rappelle plus)...
Je n'ai donc aucun chiffre concret car sous estimé
Selon vous quid de la conso?
Je pensais après acheter ce modèle:
http://www.cdiscount.com/maison/bricolage-outillage/voltmetre-etanche-de-moto-dc-12v-24v-affichage-led/f-1170440-qif8884161036595.html
Vous pensez qu'il pourrait me vider la batterie au bout d'un mois par exemple sans usage?
Surtout que l'électricité sur le 750 ce n'est pas ce qu'il y a de mieux
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 10:52
Tu mets un interrupteur en série avec le voltmètre...(Et un fusible), et tu es tranquille .Surtout, n'oublie pas que, même lui, il peut se mettre en court jus et te foutre le feu à la cabane si tu ne mets pas de fusible, dans le cas où tu le branches aux bornes de la batterie, pour avoir la mesure la plus réelle.
En ce qui me concerne, sur la 12, j'ai monté un ampèremètre à zéro central en série dans le circuit de charge (à  la sortie du fusible principal sur une 750 côté alternateur); j'ai pensé que c'était aussi efficace de savoir si la batterie charge ou bien se décharge avant d'être en caradouille; le seul problème, comme tout appareil de mesure....Il faut le regarder!  Pas besoin de protection , ni de penser à le couper ...En revanche, il faut bien surveiller les connections, car, si elles s'isolent, il revient au zéro, (sa position normale en fonctionnement quelques secondes après le coup de démarreur,)tu ne vois rien d'anormal mais...  ...Ca ne charge pas !!!
Tu trouves ça sur les sites d'appareils de mesure pour les bateaux de plaisance...Entre autres...
Moto : XTZ 2014 ES
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 13:34
La 1200 donne un code d'erreur quand la charge passe en dessous d'un certain voltage. Et il existe des voltmetres que l'on branche dans la prise allume cigare si on veut avoir une lecture directe: facile et efficace pour une lecture instantannee, sans aucune modification.
Autant j'ai controle le circuit de charge de mes vieilles BMW pendant des annees, autant sur la 1200 XTZ, je n'y fais pas attention...
- Non, mais c’était prévu.
CARRARA
CARRARA
Moto : XTZ750 an1991
Kms de ma moto : 87000
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 15:55
Moi j'ai mis ça
http://pages.ebay.com/link/?nav=item.view&id=391006090058&alt=web
Brancher sur +apc....tu coupe le contact et ça coupe le voltmètre....
Pas plus vite qu'a fond !!
Bruno31
Bruno31
Moto : Xtz 1200
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 16:30
CARRARA a écrit:
Moi j'ai mis ça
Tout pareil et c'est bon.
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 18:01
CARRARA a écrit:
Moi j'ai mis ça
Combien tu la payé est il de bonne facture et ou la tu fixé ? POSE D UN VOLTMETRE PERMANENT ET CONSO 504810 pleas ;)
POSE D UN VOLTMETRE PERMANENT ET CONSO Ct2rou14POSE D UN VOLTMETRE PERMANENT ET CONSO Logo_y12POSE D UN VOLTMETRE PERMANENT ET CONSO Vosges11 POSE D UN VOLTMETRE PERMANENT ET CONSO J_y_yt11  POSE D UN VOLTMETRE PERMANENT ET CONSO J_y_yt10
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 18:48
Quand le code panne 43 (sous tension) ou 51 (surtension)s'affiche. embarrassé ..Ca te fait une belle jambe quand tu es au milieu de la pampa !!!!
Tu vas m'écrire que si je vois l'ampèremètre qui se ballade dans les mêmes conditions, je ne serai guère plus avancé ...  ricane
CARRARA
CARRARA
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 18:59
J'ai du le payer 3,99€  au petit chinois d'ebay... Il a l'air étanche 15min sous un marcher ... Et j'ai pris mon +apc à l'arrivée sur le CDI et je l'ai fixer dans le cache noir(le tour de compteur quoi)
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyLun 11 Jan 2016 - 20:42
POSE D UN VOLTMETRE PERMANENT ET CONSO 231456  Pour ce tuto  bien
Du coup ben jais craqué pour
CA
PLUS
CA
POSE D UN VOLTMETRE PERMANENT ET CONSO 908339 yo man
piolan04
piolan04
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyMar 12 Jan 2016 - 8:58
Merci de vos avis!
tabar
tabar
Moto : revére ntv 650
Kms de ma moto : 100 000km
Pneu AV/AR : Mitas
Ville ou région : 30220
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyMar 12 Jan 2016 - 23:25
dédé a écrit:
Quand le code panne 43 (sous tension) ou 51 (surtension)s'affiche. POSE D UN VOLTMETRE PERMANENT ET CONSO 3426791442 ..Ca te fait une belle jambe quand tu es au milieu de la pampa !!!!
Tu vas m'écrire que si je vois l'ampèremètre qui se ballade dans les mêmes conditions, je ne serai guère plus avancé ...  POSE D UN VOLTMETRE PERMANENT ET CONSO 726643
       plus l'heure, pour savoir a quelle heure la panne est arrivée...???? sick    hyenes
J'dis ça!mais J'dis rien.... pas taper
POSE D UN VOLTMETRE PERMANENT ET CONSO Bonett10 POSE D UN VOLTMETRE PERMANENT ET CONSO OAatjW
________________
POSE D UN VOLTMETRE PERMANENT ET CONSO Mr84-110
XT 600 3TD
MessageSujet: Re: POSE D UN VOLTMETRE PERMANENT ET CONSO   POSE D UN VOLTMETRE PERMANENT ET CONSO EmptyMer 13 Jan 2016 - 7:41
Pour toi, c'est l'heure d'aller te coucher !!!
Allez, file dans ton carton, vilain !!! ricane
» montage voltmètre
» MISE EN PLACE D'UN VOLTMETRE
» Montage d'un voltmètre et d'un manomètre de pression d'huile
» XtZ 800 cm3 & conso
» conso xtze / XTZ
