Petit sabot alu Touratech Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Petit sabot alu Touratech Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Petit sabot alu Touratech Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Petit sabot alu Touratech Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Petit sabot alu Touratech Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Petit sabot alu Touratech Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Petit sabot alu Touratech Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Petit sabot alu Touratech Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Petit sabot alu Touratech Emptypar Arni Dim 17 Nov 2024 - 14:06
Petit sabot alu Touratech Emptypar Arni Dim 17 Nov 2024 - 13:13
Petit sabot alu Touratech Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Petit sabot alu Touratech Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Petit sabot alu Touratech Emptypar Fredard Sam 16 Nov 2024 - 9:43
Petit sabot alu Touratech Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Petit sabot alu Touratech Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Petit sabot alu Touratech Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Petit sabot alu Touratech Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Petit sabot alu Touratech Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Petit sabot alu Touratech Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Petit sabot alu Touratech Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Petit sabot alu Touratech Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Petit sabot alu Touratech Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Petit sabot alu Touratech Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Petit sabot alu Touratech Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Petit sabot alu Touratech Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
manuel amortisseur fourche crash tenere essence réservoir galére selle pneus feux reglage boue embrayage synchro arrière chaine phare suis longues rabaissement huile garde filtre vidange tuto
SentiNet
SentiNet
Ville ou région : Nantes
MessageSujet: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyJeu 7 Oct 2010 - 18:58
Le petit sabot Touratech n'est pas compatible avec les PC H&B, il est donc nécessaire de le retailler à l'AR au niveau des flancs et de la face inférieure.
Je reprends la photo de Plancton pour une vue du sabot d'origine et du petit touratech tel qu'il est livré :
Petit sabot alu Touratech CIMG0387
Après découpe/adaptation, voilà à quoi il ressemble :
Petit sabot alu Touratech P1010827
Petit sabot alu Touratech P1010829
Comparaison avec le sabot d'origine :
Petit sabot alu Touratech P1010831
Il ne me manque plus que les entretoises pour la fixation à L'AR. Je vais les faire tourner dans du rond d'alu diam. 25mm percé au centre à diam. 10mm.
Elles sont nécessaires pour compenser l'épaisseur des points d'ancrage présents sur le sabot d'origine :
Petit sabot alu Touratech P1010834
La fixation AR des PC H&B sont effectivement ancrés au même endroit :
Petit sabot alu Touratech P1010823
Les 90mm mesurés entre les 2 fixations du sabot touratech correspondent exactement à l'écartement intérieur des pattes- supports sur le cadre.
Je compléterai dès que j'aurai mes entretoises.
Le fennec
Le fennec
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyJeu 7 Oct 2010 - 19:44
Pas mal comme adaptation. T'as coupé le sabot à l'aide de quel outil ? Vivement la fin
SentiNet
SentiNet
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyJeu 7 Oct 2010 - 20:02
Scie à métaux, meuleuse et finition à la lime. Malgré l'épaisseur (4mm), ça se travaille pas trop mal.
Pour la fixation des platines AV du sabot touratech, j'ai démonté les 2 axes d'origine simultanément et rien a bougé.
Donc je pense que tu avais un autre axe support moteur de déserré car je n'ai eu aucune peine à replacer les 2 nouveaux axes touratech qui étaient totalement libres dans leur logement.
Pneu AV/AR : AnakeeIII & T63
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyJeu 7 Oct 2010 - 23:15
Chouette montage, vivement que ce soit monté qu'on voit les photos.
D'ailleurs je reprends celle que tu as posté sur le topic Hepco & Becker, quand tu parlais de la pompe à eau :
Petit sabot alu Touratech P1010816
CHez OTR, on trouve ça :
Petit sabot alu Touratech Otr_xt660_wapu_schutz_big_z1
http://www.off-the-road.de/XT-660-Z-Tenere/Protection/OTR-Waterpump-Protection-XT-660.html
Ca complète assez bien la protection je pense.
Petit sabot alu Touratech Barre_10
Petit sabot alu Touratech Sign-vm-net
http://www.voyages-moto.net
SentiNet
SentiNet
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyVen 8 Oct 2010 - 19:20
Finalement aucune protection complémentaire car pour toucher la pompe à eau, faudrait quand même un concours de circonstances exceptionnel avec un angle bien improbable...
Une vue d'ensemble :
Petit sabot alu Touratech P1010852
Petit sabot alu Touratech P1010853
Capot démonté, un détail annexe attire t-il votre attention ?
Petit sabot alu Touratech P1010841
Les entretoises pour la fixation AR :
Petit sabot alu Touratech P1010844
A => ep. 10mm
B => nilstop M12
C => ep. 20mm
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyVen 8 Oct 2010 - 21:17
Toi t'as déplacé ton klaxon !
SentiNet
SentiNet
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptySam 9 Oct 2010 - 11:41
Gagné ! Là où il est désormais, il prend un peu moins les projections en tout genre...
SentiNet
SentiNet
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptySam 9 Oct 2010 - 12:40
Et avec la portée offerte par ce sabot, je peux désormais bricoler sur la roue AV et la fourche sans mettre en œuvre d'instables calages :
Petit sabot alu Touratech P1010859
Petit sabot alu Touratech P1010860
Petit sabot alu Touratech P1010861
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyMar 23 Aoû 2011 - 23:32
Salut SentiNet,
Pour le klaxon, tu as acheté le kit Touratruc ou tu as bricolé un support toi même ?
J'ai bien envie de le déplacer mais 13 roro la pièce + 11 roro de fdp pour un morceau d'inox ... ça me trou le c*l Petit sabot alu Touratech 190757 )
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyMer 24 Aoû 2011 - 9:49
j'ai modifié l'emplacement du klaxon moi même sans rien acheter, là j'ai pas la moto sous les yeux et je l'ai fait y'a un bon bout de temps mais je peux regarder et faire des photos,
à l'époque ça m'avait semblé super évident que le klaxon devait être déplacé pour être moins exposé
de mémoire j'ai supprimé la pate tenant le klaxon et mis directement sur une vis qui le positionne parallèle a la route (pareil l'emplacement s'est présenté de lui même ça m'a semblé facile et simple....)
MessageSujet: Re: Petit sabot alu Touratech   Petit sabot alu Touratech EmptyMer 24 Aoû 2011 - 18:27
OK merci pour les explications Petit sabot alu Touratech 2120 je vais me pencher sur la question un week-end d'hiver à tuer Petit sabot alu Touratech 704842 comme tu dis ça n'a pas l'air bien compliqué !
Les photos que tu as déjà en ligne sont suffisantes, merci Petit sabot alu Touratech 609592
» Petit a petit la Douze prend sa place.
» Deflecteur Touratech
» selle Touratech
» Top case Touratech
» catalogue Touratech
