FOURCHE INVERSEE Emptypar SuperTiti Hier à 21:40
FOURCHE INVERSEE Emptypar Joe644 Hier à 18:56
FOURCHE INVERSEE Emptypar yop1025 Hier à 13:10
FOURCHE INVERSEE Emptypar REYNALD Mar 19 Nov 2024 - 10:58
FOURCHE INVERSEE Emptypar REYNALD Mar 19 Nov 2024 - 10:49
FOURCHE INVERSEE Emptypar REYNALD Mar 19 Nov 2024 - 10:46
FOURCHE INVERSEE Emptypar REYNALD Mar 19 Nov 2024 - 10:44
FOURCHE INVERSEE Emptypar jackal74 Lun 18 Nov 2024 - 11:58
FOURCHE INVERSEE Emptypar Arni Dim 17 Nov 2024 - 14:06
FOURCHE INVERSEE Emptypar Arni Dim 17 Nov 2024 - 13:13
FOURCHE INVERSEE Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
FOURCHE INVERSEE Emptypar yop1025 Sam 16 Nov 2024 - 23:12
FOURCHE INVERSEE Emptypar Fredard Sam 16 Nov 2024 - 9:43
FOURCHE INVERSEE Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
FOURCHE INVERSEE Emptypar J-Marc Mar 12 Nov 2024 - 12:44
FOURCHE INVERSEE Emptypar J-Marc Lun 11 Nov 2024 - 21:58
FOURCHE INVERSEE Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
FOURCHE INVERSEE Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
FOURCHE INVERSEE Emptypar thierry83 Dim 10 Nov 2024 - 9:29
FOURCHE INVERSEE Emptypar REYNALD Ven 8 Nov 2024 - 16:55
FOURCHE INVERSEE Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
FOURCHE INVERSEE Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
FOURCHE INVERSEE Emptypar REYNALD Mar 29 Oct 2024 - 20:18
FOURCHE INVERSEE Emptypar REYNALD Mar 29 Oct 2024 - 20:00
FOURCHE INVERSEE Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
crash arrière tenere feux phare selle pneus manuel suis rabaissement tuto embrayage essence huile filtre vidange synchro boue fourche chaine amortisseur reglage longues réservoir galére garde
Le Deal du moment : -23%
199 €
 FOURCHE INVERSEE
xtz 750 974
xtz 750 974
Moto : yamaha xtz 750
Kms de ma moto : 53500
Pneu AV/AR : michelin t63 av et arr
Ville ou région : st benoit ile de la reunion
MessageSujet: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 24 Mar 2015 - 8:17
Bonjour a tous j'ai l'acquisition d'un complet avant de YAMAHA WRF 400 (tés , 2 tubes de fourches jante et étrier ) je vais essayer de les monter je voulais savoir pour l'axe lequel utilisé wrf ou xtz merci d'avance si quelqu'un a déjà fait ce montage pourrai-je avoir des conseil merci d'avance.
dambzh
dambzh
Moto : 1200 ZRX 2004
Kms de ma moto : 45000
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 24 Mar 2015 - 20:46
si les axes sont les mêmes, tu peux garder celui du WRF autrement il faut adapter les tés à l'axe du XTZ
mais si tu ne savais pas ça, je te conseille d'aller voir un pro, tu touches à un élément de sécurité et il ne faut pas trop jouer avec ça.
FOURCHE INVERSEE Carte_postale_3
Genfy
Genfy
Kms de ma moto : 40 000
Ville ou région : Annecy Rhone-Alpes
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 24 Mar 2015 - 22:51
c'est faisable mais il y a de la modif à faire FOURCHE INVERSEE 242583
d'abord ajuster/modifier/fabriquer l'axe de colonne afin qu'il s'adapte bave
ensuite remplacer le pied de fourche droit afin de le remplacer par un modèle équipé des supports étrier  embarrassé
trouver un étrier (montage à droite) + un disque,  avec un peu de bol tu dois pouvoir récupérer les durites de frein clin d\'oeil
acheter un moyeu double disques pour wrf, yzf , yz , wrz ou adapter un moyeu d'une autre moto ou celui de ta 750 et rerayonner le cercle rock cool
et pour finir, faire une bonne préparation de la fourche, déjà que sur la 400 elle a tendance à être trop souple alors sur un xtz 750 ça va avoir tendance à pomper dangereusement bequilles
Pneu AV/AR : toujours sale
Ville ou région :
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMer 25 Mar 2015 - 6:38
d'abord ajuster/modifier/fabriquer l'axe de colonne afin qu'il s'adapte :°] simple travail de tournage fraisage environ 90€
ensuite remplacer le pied de fourche droit afin de le remplacer par un modèle équipé des supports étrier  embarrassé Pas utile, si passage en 320 mm ( ex: 950 superenduro ) 280€ disque 320 brembo avec adaptateur
et pour finir, faire une bonne préparation de la fourche, déjà que sur la 400 elle a tendance à être trop souple alors sur un xtz 750 ça va avoir tendance à pomper dangereusement Changement de ressort par soit du progressif soir du hard ( 150€ jeu de ressort olhins avec huile de fourche
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMer 25 Mar 2015 - 7:11
Bonjour merci beaucoup pour vos mp sa va m'éclairer un peu plus sur les modification a prévoir hier j'ai commencer le démontage. Pas facile les vis de fourche rouillée .
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMer 8 Avr 2015 - 7:30
Bonjour je viens un vous résumez un peu l'avancement de mon projet, fourche XTZ  enlever axe de tés WRF retirer passage a la presse obligatoire mais facile a enlever ( j'ai pu le faire moi même lol ) par contre celle de la st je vous explique pas . L'axe enlever je la met dans celle du WRF et la trop petit de de rien et pourtant on ma dit que sans rentrer nickel sur le net et la passage obligatoire par un tourneur j'ai déposer hier et la j'attend...
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMer 29 Avr 2015 - 14:03
Bonjour mon projet avance tous doucement hier j'ai récupérer le té chez le tourneur facture de 70€ avec... Montage ce matin pas ci facile avec roulement neuve un petit jeux que j'ai pu enlever avec une bague pour ajuster. Fourche monter je suis vraiment content maintenant trouver une solution pour contacteur clés et starter la suite bientôt gaz....
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMer 29 Avr 2015 - 15:46
perso j'avais essayé avec les tés de fourche d'un KLX650R, le pivot est le même, et il y a l'emplacement pour le neimann!avec des ressorts progressifs çà le faisait!
j'ai vendu la XTZ avec fourche origine et gardé la fourche inversée(j'avais pas trouvé le disque de 320 encore, et avec le disque de 250 c'était sport!!)
FOURCHE INVERSEE Barre_10
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 30 Avr 2015 - 7:26
ok moi je vais prendre les WAWES BRAKING je pense que sa va les faire ces un peu comme celles des rallye  raid . Par contre je vais peut être investir dans une tête de fourche rallye un site a me conseiller qui me livrer je suis de l'ile de la REUNION merci de vos commentaire.
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 12 Mai 2015 - 8:55
Bonjour je viens vous donner des nouvelles le montage avance tout doucement j'ai voulu mettre des photo mes j'arrive pas. Fourche ok monter j'ai installer un kit chaîne neuve DID avec un pignon 15 pneu avant et arrière neuve MICHELIN T63 que je trouve le profil sympas pas encore tester . La moto a déjà une autre allure ....
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 12 Mai 2015 - 9:41
Pour les photos, il y a un tuto très bien fait!
Les T63 sont tres bien, un peu "tendre" pour le poids de la 750! J'ai bouffé l'avant en 1500bornes
Aller montre nous tes avancees!
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 9 Juil 2015 - 14:38
Bonjour je reviens vers vous pour la suite de mon projet, qui avance doucement désoler pour les photos j'arrive pas a les envoyé (si quelqu'un veut je peu l'envoyer par mail pour qu'il le met sur le site pour moi). Je l'ai essayer pour la première fois la moto réagi mieux avec sa nouvelle fourche moto un peu plus haute plus légère sur la direction et surtout de plonge plus de l'avant. Par contre le freinage avec le disque de la WRF 450 d'origine une horreur pour le maitre cylindre ces celui d'une r6 2005 d'où ma question quelqu'un a déjà mis un kit 280 en OVERZYDE je crois qu'on dit comme sa de BRAKING avec patte de déport sera efficace ??? merci d'avance
Genfy
Genfy
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 9 Juil 2015 - 19:14
pas sur qu'il y est la place avec le rayonnage en 21 , mais si ça passe faut mettre du 320mm !!! sur les 450 de supermot ils montent tous ça clin d\'oeil
Ville ou région :
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 9 Juil 2015 - 21:28
J'ai une WP avec simple disque en 300 sur mon africa ( avant d'origine 950 SE ) le freinage est un peu beaucoup limite en mode "sport" n'hésite pas à instaler un 320 mm ( ça se monte très bien )
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyVen 10 Juil 2015 - 9:13
Bonjour merci de vos conseil je pense prendre un 320 mm en braking et je vous dirais le résultat
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyVen 10 Juil 2015 - 15:29
 pour la tete de fourche rally, il y en a une à vendre la : nb-pièces-moto.com
tu demandes à Brice ..
Ville ou région :
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptySam 11 Juil 2015 - 6:09
Brembo est moins cher clin d\'oeil clin d\'oeil
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyMar 28 Juil 2015 - 12:48
Bonjour a tous mon disque avant 320 mm enfin arrivée avec sa patte de déport demain je l'installe . Je voudrais savoir si dans vos vous connaissez pas quelqu'un qui vend un amortisseur d'occas style EMC BITUBO OHLINS merci d'avance gaz a tous.
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 13:27
FOURCHE INVERSEE Www.servimg
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 13:30
Bonjour petite question j'aimerai bien vous montrez ma moto mais j'arrive pas a mettre les photo comment faire svp.
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 13:39
FOURCHE INVERSEE 00000000000000000000000000000004?d=wavatarFOURCHE INVERSEE Moi_1712
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 13:52
FOURCHE INVERSEE Moi_1713
La je crois j'arrive en envoyer les photo.
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 13:55
FOURCHE INVERSEE Moi_1714
L'arrière modifier légèrement pour changer un peu .
tlaloc
tlaloc
Moto : xtz 750
Kms de ma moto : 80 0000
Ville ou région : versailles
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 14:48
alors sa donne quoi???
xtz 750 974
xtz 750 974
MessageSujet: Re: FOURCHE INVERSEE   FOURCHE INVERSEE EmptyJeu 10 Sep 2015 - 15:20
Ben honnêtement l'agilité de la moto et bien meilleur plus rigide mais je vais modifier l'amorto arrière qui et du coup trop souple le freinage avec un disque 320mm change la vie .
FOURCHE INVERSEE
» Fourche inversée
» Fourche Wrf ?
» fourche xtr 660
» Durcissement fourche
» Ressort de fourche
