diametre joint bouchon vidange carter t700 Emptypar Christophe M Aujourd'hui à 16:43
diametre joint bouchon vidange carter t700 Emptypar hdmanillac Hier à 9:01
diametre joint bouchon vidange carter t700 Emptypar jean-pierre 74 Lun 13 Mai 2024 - 17:27
diametre joint bouchon vidange carter t700 Emptypar Mer14 Dim 12 Mai 2024 - 22:13
diametre joint bouchon vidange carter t700 Emptypar benproof Dim 12 Mai 2024 - 16:33
diametre joint bouchon vidange carter t700 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
diametre joint bouchon vidange carter t700 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
diametre joint bouchon vidange carter t700 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
diametre joint bouchon vidange carter t700 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
diametre joint bouchon vidange carter t700 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
diametre joint bouchon vidange carter t700 Emptypar oustad Lun 29 Avr 2024 - 19:03
diametre joint bouchon vidange carter t700 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
diametre joint bouchon vidange carter t700 Emptypar ST44 Sam 27 Avr 2024 - 18:07
diametre joint bouchon vidange carter t700 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
diametre joint bouchon vidange carter t700 Emptypar meux Ven 26 Avr 2024 - 18:44
diametre joint bouchon vidange carter t700 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
diametre joint bouchon vidange carter t700 Emptypar MB Mer 24 Avr 2024 - 21:40
diametre joint bouchon vidange carter t700 Emptypar aulo Mar 23 Avr 2024 - 13:54
diametre joint bouchon vidange carter t700 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
diametre joint bouchon vidange carter t700 Emptypar Buszost Ven 19 Avr 2024 - 22:56
diametre joint bouchon vidange carter t700 Emptypar Buszost Ven 19 Avr 2024 - 22:45
diametre joint bouchon vidange carter t700 Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
diametre joint bouchon vidange carter t700 Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
diametre joint bouchon vidange carter t700 Emptypar Palex Mar 16 Avr 2024 - 22:33
diametre joint bouchon vidange carter t700 Emptypar thierry Mar 16 Avr 2024 - 7:14
huile arrière amortisseur galére phare manuel chaine rabaissement carburateur filtre vidange feux fourche garde boue embrayage pneus réservoir synchro tuto suis reglage essence tenere longues crash
-55%
Coffret d’outils – STANLEY – STMT0-74101 – 38 pièces – ...
21.99 € 49.04 €
thierry64
thierry64
Moto : T700
Pneu AV/AR : pirelli origine
MessageSujet: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyVen 1 Avr 2022 - 15:15
Salut à tous,
Et-ce-que quelqu'un pourrait me donner le diamètre du joint du bouchon de vidange pour une T7, j'ai regardé sur le net mais j'ai pas trouvé ou alors j'ai mal regardé. Pas envie de déranger un mécano chez mon concessionnaire juste pour cela.
Merci d'avance
pS: Avez-vous un site préféré pour l'achat de pièces pour un entretien  ?
th
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyVen 1 Avr 2022 - 17:44
Salut Thierry?
C'est du 14 d'après le manuel d'atelier .
thierry64
thierry64
Moto : T700
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyVen 1 Avr 2022 - 19:39
Dédé a écrit:
Salut Thierry?
merci Dédé !!!!!
je vais commander des joints ,filtre et huile pour me coller à l'entretien bien
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptySam 2 Avr 2022 - 16:13
Tu peux venir à la maison pour faire ça si tu veux .
thierry64
thierry64
Moto : T700
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptySam 2 Avr 2022 - 18:29
j'ai encore 1500 km à rouler avant les 10 000 km. j'avais besoin de plaquettes de frein arrière j'ai donc commandé ce qu'il faut pour les changer et faire l'entretien que je ferai plus tard. merci quand même
Par contre il me reste 2 mm d'épaisseur de plaquette alors que je n'ai pas beaucoup roulé et je roule tjrs tranquillou , c'est bizarre cette usure, sur mon ancienne ténéré 660 je l'avais revendue à 30 000 km et mes plaquettes étaient encore bonnes !!!!!!!  j'ai commandé des "métal fritté " je verrai s'ils elles tiennent plus longtemps
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptySam 2 Avr 2022 - 19:11
Il me semble bien que le diamètre du disque arrière n'est pas très grand, ce qui nécessite davantage d'effort pour freiner la roue par le disque ...
thierry64
thierry64
Moto : T700
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyDim 3 Avr 2022 - 13:35
crois-tu qu'il est différent de la 660 ?
C'est pas bien grave de toute façon c'est changé en 5 min.
merci Dédé
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyLun 4 Avr 2022 - 7:31
Même diamètre .
thierry64
thierry64
Moto : T700
MessageSujet: Re: diametre joint bouchon vidange carter t700   diametre joint bouchon vidange carter t700 EmptyLun 4 Avr 2022 - 16:40
Dédé a écrit:
Même diamètre .
merci ! donc ce n'est pas la raison puisque j'ai fait 30 000 km avec les mêmes plaquettes sur la 660 et seulement 9000 km sur la 690. probablement des plaquettes plus tendres.
Merci DD
» Diamètre joint de vidange
» Filetage bouchon de vidange carter moteur . A l'aide !!
» Joint de bouchon de réservoir XTZ 750
» Joint bouchon réservoir essence XTZ750
» Bouchon vidange
