Probleme allumage ( probleme resolu )  Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Probleme allumage ( probleme resolu )  Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Probleme allumage ( probleme resolu )  Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Probleme allumage ( probleme resolu )  Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Probleme allumage ( probleme resolu )  Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Probleme allumage ( probleme resolu )  Emptypar oustad Lun 29 Avr 2024 - 19:03
Probleme allumage ( probleme resolu )  Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Probleme allumage ( probleme resolu )  Emptypar ST44 Sam 27 Avr 2024 - 18:07
Probleme allumage ( probleme resolu )  Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Probleme allumage ( probleme resolu )  Emptypar meux Ven 26 Avr 2024 - 18:44
Probleme allumage ( probleme resolu )  Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Probleme allumage ( probleme resolu )  Emptypar MB Mer 24 Avr 2024 - 21:40
Probleme allumage ( probleme resolu )  Emptypar Mer14 Mer 24 Avr 2024 - 10:42
Probleme allumage ( probleme resolu )  Emptypar aulo Mar 23 Avr 2024 - 13:54
Probleme allumage ( probleme resolu )  Emptypar yd64 Mar 23 Avr 2024 - 8:34
Probleme allumage ( probleme resolu )  Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Probleme allumage ( probleme resolu )  Emptypar Buszost Ven 19 Avr 2024 - 22:56
Probleme allumage ( probleme resolu )  Emptypar Buszost Ven 19 Avr 2024 - 22:45
Probleme allumage ( probleme resolu )  Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Probleme allumage ( probleme resolu )  Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Probleme allumage ( probleme resolu )  Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
Probleme allumage ( probleme resolu )  Emptypar Palex Mar 16 Avr 2024 - 22:33
Probleme allumage ( probleme resolu )  Emptypar thierry Mar 16 Avr 2024 - 7:14
Probleme allumage ( probleme resolu )  Emptypar aulo Mar 9 Avr 2024 - 13:09
Probleme allumage ( probleme resolu )  Emptypar Mer14 Mar 9 Avr 2024 - 9:09
pneus fourche réservoir chaine rabaissement tuto amortisseur galére phare longues manuel essence filtre huile arrière reglage embrayage crash suis carburateur synchro garde vidange feux tenere boue
-21%
39.59 € 49.99 €
oufrider2728
oufrider2728
Moto : xtz 750
Kms de ma moto : 540000
Ville ou région : Normandie
MessageSujet: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 18:10
Voila le problème, suite a un changement de moteur, ma moto avait beaucoup de mal a démarrer ( j'ai juste démarrer deux fois 30 secondes et coupé le contact )
En faisant un contrôle de l'étincelle aux bougies je me suis rendu compte qu'elle était très faible puis a la suite de mes essai je n'ai plus du tout d'étincelle aux bougies...
Le problème c'est que j'ai quasiment tout contrôlé et la je sèche totalement
Voici ce que j'ai controlé/changé
Bougies neuves
Enroulement de bobine primaire et secondaire OK
Enroulement du stator OK
Diode OK
Batterie charger ( j'ai meme testé de brancher une batterie de voiture au cas ou la mienne manque d'amperage )
Transistor du CDI changer ( 2SD2141 par un 2SD1071 )
Capteur allumage OK
Si quelqu'un a une idée ou une solution ca pourrais grandement m'aidé  doigtsenV
oufrider2728
oufrider2728
Moto : xtz 750
MessageSujet: Re: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 21:43
Bon j'ai enfin trouvé mon probleme et c'est bien bete. On en apprend tout les jours cool
Le transistor que j'ai remplacé etait bel et bien HS mais j'ai fait une boulette avec le nouveau.
Comme on peux le voir mon ancien transistor n'avait pas une partie en metal au dos, je pensais que c'etait pour aidé la dissipation thermique mais non ca me le mets en court circuit a priori. J'ai essayé en l'isolant du radiateur et la miracle une belle etincelle !  Double V
Si ca peux servir a quelqu'un un jour je post les photos, il me reste plus qu'a trouver un transistor sans la plaque en metal au dos
Probleme allumage ( probleme resolu )  1521059830-img-0793
Probleme allumage ( probleme resolu )  1521059829-img-0794
J'ai ce CDI la au cas ou:
Probleme allumage ( probleme resolu )  Img_5210
MessageSujet: Re: Probleme allumage ( probleme resolu )    Probleme allumage ( probleme resolu )  EmptyMer 14 Mar 2018 - 22:12
bien
» Probléme puissance (RESOLU)
» please help me...please help me " problème refroidissement"[RÉSOLU]
» Problème régulateur / alternateur ? Résolu P3 !
» problème d'allumage
» problème allumage
