UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar REYNALD Lun 6 Mai 2024 - 17:08
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar REYNALD Lun 6 Mai 2024 - 17:06
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Mich77 Dim 5 Mai 2024 - 11:08
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar oustad Lun 29 Avr 2024 - 19:03
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar ST44 Sam 27 Avr 2024 - 18:07
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar meux Ven 26 Avr 2024 - 18:44
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar REYNALD Ven 26 Avr 2024 - 11:53
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar MB Mer 24 Avr 2024 - 21:40
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Mer14 Mer 24 Avr 2024 - 10:42
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar aulo Mar 23 Avr 2024 - 13:54
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar yd64 Mar 23 Avr 2024 - 8:34
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar yop1025 Lun 22 Avr 2024 - 20:30
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Buszost Ven 19 Avr 2024 - 22:56
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Buszost Ven 19 Avr 2024 - 22:45
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Palex Mar 16 Avr 2024 - 22:33
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar thierry Mar 16 Avr 2024 - 7:14
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar aulo Mar 9 Avr 2024 - 13:09
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Emptypar Mer14 Mar 9 Avr 2024 - 9:09
amortisseur feux tenere essence synchro suis rabaissement garde phare filtre crash boue huile carburateur reglage vidange réservoir tuto pneus chaine embrayage arrière longues galére manuel fourche
-50%
-50% Baskets Nike Air Huarache Runner
69.99 € 139.99 €
MessageSujet: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyDim 26 Jan 2014 - 18:52
C'est seulement la seconde fois que je pars à moto, mais la 10ème à NAJAC (AVEYRON)
En 2011 c'était avec la F800GS, cette année avec ma 660XTZ.
Amateur de patrimoine, je vais me faire des virées d'une journée (sur départementales uniquement.).
Pour aller à La Couvertoirade (cité templière), il faut traverser l'Aveyron de part en part, 154 km seulement mais 3h16 d'après michelin, histoire de vous situer le type de route.
Comme je n'ai pas envie de m'arrêter toutes le 5 mn pour déplier la carte ni d'acheter un GPS, ni d'essayer d'adapter celui que j'ai pour la voiture, je me suis dit : pourquoi ne pas fabriquer un dérouleur manuel perso ?
J'ai vu un lien très bien fait par quelqu'un qui en a fabriqué un avec une cassette vidéo,
http://www.google.fr/imgres?imgurl=http://www.dl650.org/photos/pbsoluces/renaud/derouleur/79.jpg&imgrefurl=http://www.dl650.org/photos/pbsoluces/renaud/derouleur/&h=570&w=760&sz=52&tbnid=Jzejt5l4eitm0M:&tbnh=111&tbnw=148&zoom=1&usg=__45KsQC3u94mImZNja-Z7j9nm0Bw=&docid=AdEVdfmCp2dLQM&sa=X&ei=MkHlUt_QLqeW0QW9yYG4AQ&ved=0CDoQ9QEwAg&dur=35
mais je voulais faire mon truc perso, sans copier bêtement.
Après avoir bien cogité, je voulais faire le moins cher possible, pas une question de problème financier, mais envie de récupérer au max et d'improviser.
J'ai donc choisi une boîte hermétique transparente, achetée chez CORA, étanche, avec joint d'étanchéité inclus dans le couvercle, et 4 clips de verrouillage (un de chaque côté), coût 3 €...
J'ai coupé les deux clips les plus longs, pour passer les axes de dérouleur ;
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8515
Pour les axes, j'ai choisi deux belles branches bien droites,  d'un bois bien sec (merci mon jardin).
Après avoir percé les trous de part en part, çà donne çà :
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8610
Restait à installer aux extrémités, deux petites tiges métalliques, empruntées à une vieille grille de four pour bien tendre le papier :
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8611
Et à faire une fente au centre de chaque baguette pour insérer l'amorce du papier :
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8612
Ensuite, l'élastique qui va bien pour la tension du papier et mettre des embouts en caoutchouc en bout de chaque axe, et bien sûr de rédiger le parcours (je ne suis pas en retard, mais je considère que les préparatifs font partie des vacances).
Voila le produit fini, en gros 200 grammes, parfaitement étanche, il fonctionne parfaitement dans les deux sens, il me reste à trouver un moyen de le fixer, il me reste trois mois, je ne suis pas inquiet  bien Si vous avez une idée, je suis preneur, évidemment.
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8613
olivier59
olivier59
Moto : Xtz 1200
Kms de ma moto : 39500
Pneu AV/AR : Michelin PR4
Ville ou région : Douglas
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyDim 26 Jan 2014 - 19:00
Perso j'ai un touratech et un tripy2.
Sinon tu perces 4 trous au fond et tu fixes une plaques alu à l'intérieur et extérieur pour le fixer.
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyDim 26 Jan 2014 - 19:07
Oui, c'est déjà prévu mais pour fixer l'ensemble à la moto, j'ai encore diverses options à l'étude. Tu as une idée ?
pas mal !
dans la meme idee, j'avais pensé a la boite pour y mettre mon GPS auto...
tu le fixe au guidon comment ?
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyDim 26 Jan 2014 - 19:14
Frank a écrit:
pas mal !
J'ai récupéré une lampe qui se fixe sur le vtt, avec un clip et une partie débrayable  qui permet d'enlever le corps du boitier.
Je m'oriente vers cette solution.
J'ai entortillé un morceau de chambre à air autour de la barre horizontale du guidon, et tient avec deux colliers de serrage, si je vois que çà reste assez rigide je prendrai cette option, la boîte est tellement légère, sauf autre idée, bienvenue clin d\'oeil
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyDim 26 Jan 2014 - 21:30
bonjour
Modèle luxe avec GPS et température incorporé.
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Images?q=tbn:ANd9GcT65Wm1LrzP99WgS_3O7NBD04Kdo7Q9otNpd31Xb4ROne8PTI1ebA
Et celui avec plusieurs itineraires
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Images?q=tbn:ANd9GcSAr3fk6R2W2zK0FL7ZkSlmK4-a7mfn5tvniKOBn4dPTK_vD5W4mQ
OK : je sort....
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptySam 8 Fév 2014 - 11:01
Suite et fin de l'installation, après avoir reçu çà :
http://www.cricel.com/hr/643-systeme_fixation_sur_guidon_velo_moto__hr_herbert_richter_1685.html
Après avoir fait les 7 encoches nécessaires dans le plastique hyper dur de la boîte, avec une glissière sous chaque encoche, pour faire descendre le boîtier et bien le caler, çà donne çà :
Même pas eu besoin d'une pièce métallique  pour rigidifier, tellement la boîte est épaisse. L'ensemble étant protégé par la bulle haute, m'étonnerait fort que çà bouge.
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8616
Les puristes pourront toujours dire que c'est moche et que çà fait bricolage. UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER 916683
M'en fous, c'est efficace, et m'est revenu pas cher et çà m'a occupé un moment. UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER 49290
Il faut juste que j'enlève le morceau de mousse et les deux colliers, puisque c'était pour une autre idée de fixation.
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptySam 22 Fév 2014 - 12:47
Suite et fin... Le dérouleur présenté ci-dessus, était parfait de fonctionnement, mais faisait un peu trop alimentaire à mon goût.
J'ai fini par dénicher dans mon bordel, une boîte qui le fera mieux. Même principe de fonctionnement éprouvé, étanchéité testée ce matin sous une pluie battante.
Nouveau dérouleur bon pour le service. UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER 46975
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8619
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8620
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER Dscf8621
voldepegase
voldepegase
Moto : 750 super tenere
Kms de ma moto : 53000
Ville ou région : narbonne
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyJeu 24 Sep 2015 - 21:07
Beau boulot
BIG
BIG
Moto : T 700 Rally Edit
Kms de ma moto : 4500
Ville ou région : var
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyMar 11 Avr 2017 - 10:20
Merci GROSMONO. bravo
Hier j'ai fait une petite virée de 400 bornes dans les Alpes de Haute Provence et j'ai voulu emprunter au maximum des routes ( voire chemins ) que je ne connaissais pas... Et j'ai dû sortir la carte 10 fois et faire demi- tour autant...
D'où l'idée de copier.... ton idée ... Je peux ? pas de brevet déposé ? Very Happy
V
Je n'aurais pas un cylindre de trop ???UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER 261789
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyMer 12 Avr 2017 - 20:25
V
C'est une blague ? l'idée est à disposition de ceux que ça intéresse, évidemment clin d\'oeil
Phil11
Phil11
Kms de ma moto : 103.000
Pneu AV/AR : Dunlop Trailmax
Ville ou région : Occitanie.
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyMer 12 Avr 2017 - 20:37
pas mal la boite noire ;)
UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER 909
etinag
etinag
Pneu AV/AR : Cramponnés
MessageSujet: Re: UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER   UN DEROULEUR DE ROAD BOOK MANUEL PAS CHER EmptyJeu 13 Avr 2017 - 9:47
Y'a une boîte noire sur les 660 ?
Djû le progrès; je pensais que c'était réservé uniquement à l'aviation  lol!
» Dérouleur de road book pas cher
» dérouleur de road book
» Recherche road-book manuel
» ROAD BOOK HIVER
» Infos road book..
SUPER TENERE XTZ :: BALADES, VOYAGES, SORTIES... :: PRÉPARATION RAIDS, VOYAGES, VIRÉES... :: MATOS de voyage-
