» boite a outils GIVI S250
Amelioration freinage xtz660 Emptypar pooppy1200 Hier à 22:40
Amelioration freinage xtz660 Emptypar REYNALD Lun 27 Mai 2024 - 11:56
» bobines crayon
Amelioration freinage xtz660 Emptypar crops Lun 27 Mai 2024 - 8:07
Amelioration freinage xtz660 Emptypar Licmn Mer 22 Mai 2024 - 11:30
» Boite à outils
Amelioration freinage xtz660 Emptypar JMM34 Mar 21 Mai 2024 - 14:52
» XTZ 750 de 1989
Amelioration freinage xtz660 Emptypar Umul Mar 21 Mai 2024 - 11:39
Amelioration freinage xtz660 Emptypar hdmanillac Dim 19 Mai 2024 - 9:01
Amelioration freinage xtz660 Emptypar jean-pierre 74 Lun 13 Mai 2024 - 17:27
Amelioration freinage xtz660 Emptypar Mer14 Dim 12 Mai 2024 - 22:13
Amelioration freinage xtz660 Emptypar benproof Dim 12 Mai 2024 - 16:33
Amelioration freinage xtz660 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Amelioration freinage xtz660 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Amelioration freinage xtz660 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Amelioration freinage xtz660 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Amelioration freinage xtz660 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Amelioration freinage xtz660 Emptypar oustad Lun 29 Avr 2024 - 19:03
Amelioration freinage xtz660 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Amelioration freinage xtz660 Emptypar ST44 Sam 27 Avr 2024 - 18:07
Amelioration freinage xtz660 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Amelioration freinage xtz660 Emptypar meux Ven 26 Avr 2024 - 18:44
Amelioration freinage xtz660 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Amelioration freinage xtz660 Emptypar MB Mer 24 Avr 2024 - 21:40
Amelioration freinage xtz660 Emptypar aulo Mar 23 Avr 2024 - 13:54
Amelioration freinage xtz660 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Amelioration freinage xtz660 Emptypar Buszost Ven 19 Avr 2024 - 22:56
fourche filtre huile embrayage essence longues rabaissement tenere crash arrière galére garde pneus tuto manuel synchro suis réservoir boue carburateur vidange phare amortisseur reglage feux chaine
newbie
Moto : xt660z
Ville ou région : Paris
MessageSujet: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyMer 16 Nov 2011 - 20:21
Alors voila, bizarrement , même si la xtz660 freine bien, je trouve qu'elle manque de mordant. Est-ce que vous avez fait des modifications pour améliorer ca ? Est-ce que je suis le seul a trouver que les sensations sont un peu "floues" ?
gui
Moto : tenere 660 xtz
Ville ou région : RIEZ PACA
MessageSujet: amélioration freinage   Amelioration freinage xtz660 EmptyMer 16 Nov 2011 - 20:54
Déja si tu veux avoir une commande avec du répondant tu dois penser à changer ton liquide de freins tous les 2 ans avec une bonne purge et si tu veux optimiser encore tu mes des durites aviation et tu auras plus de mordant car les durites avia ce dilatent pas avec la pression.
ciaooo
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyMer 16 Nov 2011 - 22:14
non, moi le freinage, ça va....
goodredwine
goodredwine
Moto : 1200 XTZ Worldcrosser
Kms de ma moto : 22000
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyJeu 17 Nov 2011 - 13:39
bon freinage mais effectivement serait meilleur si plus de mordant ! je rejoins les conseils de GUI.
gerald
Moto : XTZ 660 TENERE
Ville ou région : ANTIBES 06600
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyJeu 17 Nov 2011 - 17:46
Tu ne dois certainement pas "beaucoup" l'emmener sur les pistes ta moto ,parceque sur la terre , on cherche surtout à proscrire la brutalité lors des freinages ,à fortiori sur la terre , et je ne parle meme pas dans le gras !!! alors pour une utilisation exclusivement sur le goudron ,le montage de durite aviation se conçoit mais quelle interet de posseder un xtz pour faire de la route ???
Les gouts et les couleurs ?!?!!!!
Le fennec
Le fennec
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyJeu 17 Nov 2011 - 20:56
C'est exactement ce que je pense. Tres bien dit cheers
yann13
Moto : Honda NX250,YZF-R1, bientôt XTZ660 Ténéré
Ville ou région : Bouches du Rhones
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyVen 30 Mar 2012 - 11:52
Pour utilisation route,j'ai deux ressort de fourche Ohlins,durites avia avant et arriere ,liquide de frein Motul RBF600 et la tu peux faire des freinage de trapeur..Smile mais sur que pour le TT ça sera un doigté hors pair qu'il te faudra...!
goodredwine
goodredwine
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptySam 31 Mar 2012 - 18:08
lundi dernier j'ai commandé chez OTR :
- plaquettes AR
- roulements AV (2) + bagues étanches (2)
- roulements AR (3) + bagues étanches (2)
- amortisseurs de couple
- kit nettoyage filtre haute perf (DNA)
- vis plastique pour bulle
... que j'ai reçu jeudi avec , en cadeau, un petit sachet d'oursons Haribo (probablement pour s'excuser que la facture est en Allemand ricane )
et aussi chez "123p_eus.fr" : 1x Full Bore USA M41 arrière à 70,70€ port compris (également reçu jeudi, mais sans bonbons Haribo , même si la facture est aussi en allemand ricane )
alors j'ai changé cet aprèm les plaquettes AR + changement liquide DOT4 AR : j'ai vraiment été surpris par la facilité de remplacement des plaquettes ! j'ai cherché si y'avait pas une astuce qui compliquait un tantinet l'opération, mais non !
quelques kms pour vérifier et commencer à roder les plaquettes , OK ; mais ça freine vraiment pas au début !
lorsqu'elles seront rodées, je m'attaquerai au changement du pneu AR et au remplacement des roulements avec bagues .
hello
Le fennec
Le fennec
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 7:07
Suêr intéressant tout ça. N'hésites pas à nous faire un tuto trosuper
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 7:18
Le fennec a écrit:
Suêr intéressant tout ça. N'hésites pas à nous faire un tuto Amelioration freinage xtz660 3199447018
oui +1 !
et ton avis sur le pneu (que je ne connaissais pas) au prix super intéressant ! tu le montes toi même ? si oui comment fais tu pour l’équilibrage ?
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 7:31
salut pour moi, un équilibrage AR n'est pas justifier surtout pour rentrer dans un chemin 1h plus tard.....je parle pas pour les routeuses..... clin d\'oeil
(mais ce n'est que mon avis, a moi même).. Very Happy
Pneu AV/AR : AnakeeIII & T63
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 10:06
J'avais eu pareil Very Happy
Doivent avoir des accords commerciaux avec Haribo.....
Amelioration freinage xtz660 Barre_10
Amelioration freinage xtz660 Sign-vm-net
http://www.voyages-moto.net
jeanmi
jeanmi
Moto : 1200 XTZ '16
Kms de ma moto : 29000
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 10:29
Amelioration freinage xtz660 170742 pour rouler dans les chemins ou à 100kms/h, je vois pas l'interet!!
en plus, si il faut que j'aille me faire ch*er chez un cons.pour equilibrer les roues alors que je monte mes pneus moi même......
semper carpe diem
didiercoca
didiercoca
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 10:35
ca se monte facilement seul des pneus arriere???
jeanmi
jeanmi
Moto : 1200 XTZ '16
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 10:42
bien sur....un peu de graisse sur le talon du pneu, des bonnes chaussures (en basket, c'est moyen, la semelle se déforme!) et en avant!
et surtout, pas de démonte-pneus au remontage non non !
le plus chiant, c'est pour faire passer la valve de la chambre dans le trou de la jante pas content (j'ai des trop gros doigts, je passe mal dans le pneu....)
semper carpe diem
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 11:25
pour décoller le pneu AR ... ricane ..c'est pas mal non plus Amelioration freinage xtz660 730457
si je suis a l'atelier ....c'est cool ,avec mon étaux,et une planchette! Amelioration freinage xtz660 916683 si non dur dur.
goodredwine
goodredwine
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 13:53
bof, c'est galère uniquement et seulement pour le décollage du pneu de la jante !!! ensuite sortir le pneu ça se fait assez bien ! mais je reviendrai début mai pour montrer une astuce que je vais tenter et qui devrait marcher du diable ...
pour revenir au sujet du message : "comment donner du mordant aux freins" , je peux préciser que les plaquettes "classiques" en organique offrent plus de mordant que les "SINDEX" (synthétique, plus résistantes dans le temps, plus agressives pour le disque -> attention disques à 65€ !! , valables pour conduite sportive après temps de chauffe);
j'ai donc remplacé les plaquettes AR qui étaient des Brembo sindex placées par le proprio 1ère main de ma Z , par des Lucas organiques qui ont mis du temps à se roder car mes disques en ont 'pris un coup' d'avoir été frictionnés par des plaquettes sindex !!
il me semble avoir plus de mordant avec ces nouvelles plaquettes !! mais bon, l'effet du "tout nouveau / tout beau" peut fausser l'appréciation , à confirmer ...
hello
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 14:04
ha!!!!
b
????????????début mai???????????et pourquoi pas maintenant clin d\'oeil
comment tu décolle ton pneu.....pour le reste il n'y a que les doigts de jeanmi qui m***e... Very Happy un peu??? Amelioration freinage xtz660 916683 j'sais plus comment faut dire.....endi...endicomprend pas... Amelioration freinage xtz660 492970 Amelioration freinage xtz660 301432
goodredwine
goodredwine
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 14:24
... début mai ... parce que je fais tirer mon Contiescape AR au max, et que j'ai l'intention de roder mon Fullbore M41 en mai pour partir tranquilou en Corse début juin Amelioration freinage xtz660 27894
et puis tu as déja bien dévoilé mon "idée" boxing même si ce n'est pas un étau que je compte utiliser clin d\'oeil
jeanmi
jeanmi
Moto : 1200 XTZ '16
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 18:19
je les decolle avec le pied (d'où le problème avec les baskets.....c'est plus facile en botte cross!)
si vraiment il resiste, il y a un moyen infaillible, c'est la bequille latérale d'une 750 XTZ ou d'un autre camion du même style (@T, T@, 1200XTZ, GS.....)
Tu pose la bequille sur le pneu et tu t'agrippes à la moto......ça marche à tous les coups bien
semper carpe diem
didiercoca
didiercoca
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 18:40
et vous mettez a chaque fois une nouvelle chambre a air?
didiercoca
didiercoca
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 18:42
je presente a newbie toutes mes excuses , j ai encore détourné l origine de son topic.... Amelioration freinage xtz660 230111
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyDim 1 Avr 2012 - 19:32
au niveau de la force...jeanmi...... on ne doit pas jouer dans la même coure ricane
jeanmi
jeanmi
Moto : 1200 XTZ '16
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyLun 2 Avr 2012 - 20:51
non, je change si elle a des rustines..et je garde la vieille en reserve!
semper carpe diem
jeanmi
jeanmi
Moto : 1200 XTZ '16
MessageSujet: Re: Amelioration freinage xtz660   Amelioration freinage xtz660 EmptyLun 2 Avr 2012 - 20:52
tabar a écrit:
au niveau de la force...jeanmi...... on ne doit pas jouer dans la même coure Amelioration freinage xtz660 726643
oh l'aut'e!!!!
niveau gabarit, t'as pas l'air bien loin de moiAmelioration freinage xtz660 49290
semper carpe diem
