ressorts soupapes  Emptypar benproof Aujourd'hui à 16:33
ressorts soupapes  Emptypar REYNALD Lun 6 Mai 2024 - 17:08
ressorts soupapes  Emptypar REYNALD Lun 6 Mai 2024 - 17:06
ressorts soupapes  Emptypar Mich77 Dim 5 Mai 2024 - 11:08
ressorts soupapes  Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
ressorts soupapes  Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
ressorts soupapes  Emptypar oustad Lun 29 Avr 2024 - 19:03
ressorts soupapes  Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
ressorts soupapes  Emptypar ST44 Sam 27 Avr 2024 - 18:07
ressorts soupapes  Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
ressorts soupapes  Emptypar meux Ven 26 Avr 2024 - 18:44
ressorts soupapes  Emptypar REYNALD Ven 26 Avr 2024 - 11:53
ressorts soupapes  Emptypar MB Mer 24 Avr 2024 - 21:40
ressorts soupapes  Emptypar aulo Mar 23 Avr 2024 - 13:54
ressorts soupapes  Emptypar yd64 Mar 23 Avr 2024 - 8:34
ressorts soupapes  Emptypar yop1025 Lun 22 Avr 2024 - 20:30
ressorts soupapes  Emptypar Buszost Ven 19 Avr 2024 - 22:56
ressorts soupapes  Emptypar Buszost Ven 19 Avr 2024 - 22:45
ressorts soupapes  Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
ressorts soupapes  Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
ressorts soupapes  Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
ressorts soupapes  Emptypar Palex Mar 16 Avr 2024 - 22:33
ressorts soupapes  Emptypar thierry Mar 16 Avr 2024 - 7:14
ressorts soupapes  Emptypar aulo Mar 9 Avr 2024 - 13:09
ressorts soupapes  Emptypar Mer14 Mar 9 Avr 2024 - 9:09
garde filtre tenere crash pneus suis tuto arrière carburateur feux phare manuel fourche réservoir vidange embrayage rabaissement huile chaine essence galére boue longues reglage amortisseur synchro
-45%
339 € 622 €
 ressorts soupapes
Hubert Gaudriole
Hubert Gaudriole
Moto : EX : 750 ZEPHYR 1200 ZRX 955 SPRINT ST 900XJ 1200FJ 900 SMT R 1200 S RF 900 R 1000 VTR Actuelle 750 XTZ 89 FARADAY BLUE
Kms de ma moto : 46 000 km
Pneu AV/AR : Mitas terraforce r
Ville ou région : Clermont-Ferrand Auvergne
MessageSujet: ressorts soupapes    ressorts soupapes  EmptyDim 10 Déc 2023 - 7:03
Salut à tous ,
La question du jour
En mode réglage jeux aux soupapes, je trouve 2 ressorts (admission)pas beaux, avec une couche noirâtre granuleuse , les 4 autre étant bien , voir photo, est ce de l'huile qui a stagné ici , cause inactivité, ou problème plus profond, ( joint queues de soupapes ou autre) et il faut déculasser
Et voir plus bas ? Merci pour vos idées et bon dimanche ressorts soupapes  Img_2096
ressorts soupapes  Img_2097
Sachant que moteur cogne velu à froid , retour dans la ligne conséquents qui disparaissent pratiquement a chaud , très chaud , je sais pas si c'est lié, peut être ma synchro , richesse n'est pas bonne , (carbu remis à neufs , pipe neuves , bobines neuves , bougies récentes couleurs normale
Romsch32110
Romsch32110
Moto : YAMAHA 660 XTZ 3YF
Ville ou région : MIDI-PYRENEES
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 9:22
Bonjour Hubert,
Je ne vois pas très bien sur les photos mais l'huile moteur au contact des gaz d'échappement se cokéfie (se transforme en sorte de goudron calaminé).
Donc vu que ton problème est localisé, je pencherai pour un défaut d'étanchéité des joints de queues de soupapes mais cela reste étonnant que cela ait été constaté sur les ressorts d'admission. Lorsque tu as contrôlé tes jeux tu avais combien ?
Hubert Gaudriole
Hubert Gaudriole
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 10:03
Saalut et merci pour ta réponse
Je n'ai pas les jeux exact en tête, je pourrais les avoir début janvier car la moto est "fermée" pour les fête ds mon association de mécanique
Tous les jeux à l'admission étaient mauvais, et bon à l'échappement.
Il y a seulement 2 ressorts à l'admission qui sont marqués de points et dépôt noir, marron, qui sont bien collés, le deuxième de chaque côté en partant de chaque côté du moteur vers l'intérieur. Il faut que je regarde de plus près oui les jeux concernant ces soupapes en particulier. Étonnant oui seulement 2 et à l'admission.je me tâte à déculasser pour voir les joints de queue de soupape en cause ,ou si c'est seulement des dépôts localisés ici a cause de la morphologie du moteur et de l'inactivité de celui ci 47 000 km moto de 1989 ça fait un peu plus de 1300km par an de moyenne !!!! A suivre..
En panne tu tomberas, dépanner tu essayeras, pousseras tu pleureras, à pied tu iras.
jean fioretti
jean fioretti
Moto : XTZ 700 Rallye
Kms de ma moto : 80
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 14:11
Je dirais comme Romsch32110 que l'huile a été au contact des gaz d'échappement ce qui donne ce dépot noiratre sur le ressort.
Par contre comme tu dis que les jeux a l'admission ne sont pas bon je serais enclin a penser que le probléme vient de ces jeux mauvais qui doivent provoquer une mauvaise étanchéité de la soupape.
Romsch32110
Romsch32110
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 14:52
Je rejoins l'analyse technique de Jean Fioretti. À votre place, avant de déculasser, je ferai les jeux aux soupapes et mesurerai les pressions de fin de compression ou encore mieux un test de fuite.
Romsch32110
Romsch32110
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 15:11
Ton moteur est-il équipé de poussoirs hydrauliques ?
Hubert Gaudriole
Hubert Gaudriole
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 15:23
Je vous donnerai les jeu mesurés exact a chaque soupapes d'admission la semaine prochaine, effectivement s'il sont plus important a chaque soupapes/ ressorts incriminés je comprendrais pourquoi ces deux ressorts sont marqués, sinon ce sera déculasser joint de queue j'vois pas aut chose
Hubert Gaudriole
Hubert Gaudriole
MessageSujet: Re: ressorts soupapes    ressorts soupapes  EmptyJeu 28 Déc 2023 - 15:37
Ressorts à pas progressif
ressorts soupapes
» reglages jeux aux soupapes et remplacement des joints de queues de soupapes?
» problème de ressorts
» jeu aux soupapes 750 xtz
» Choix ressorts fourche
» Tuto changement ressorts de fourche
