programmation ECU power vision Dynojet Emptypar REYNALD Lun 6 Mai 2024 - 17:08
programmation ECU power vision Dynojet Emptypar REYNALD Lun 6 Mai 2024 - 17:06
programmation ECU power vision Dynojet Emptypar Mich77 Dim 5 Mai 2024 - 11:08
programmation ECU power vision Dynojet Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
programmation ECU power vision Dynojet Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
programmation ECU power vision Dynojet Emptypar oustad Lun 29 Avr 2024 - 19:03
programmation ECU power vision Dynojet Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
programmation ECU power vision Dynojet Emptypar ST44 Sam 27 Avr 2024 - 18:07
programmation ECU power vision Dynojet Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
programmation ECU power vision Dynojet Emptypar meux Ven 26 Avr 2024 - 18:44
programmation ECU power vision Dynojet Emptypar REYNALD Ven 26 Avr 2024 - 11:53
programmation ECU power vision Dynojet Emptypar MB Mer 24 Avr 2024 - 21:40
programmation ECU power vision Dynojet Emptypar Mer14 Mer 24 Avr 2024 - 10:42
programmation ECU power vision Dynojet Emptypar aulo Mar 23 Avr 2024 - 13:54
programmation ECU power vision Dynojet Emptypar yd64 Mar 23 Avr 2024 - 8:34
programmation ECU power vision Dynojet Emptypar yop1025 Lun 22 Avr 2024 - 20:30
programmation ECU power vision Dynojet Emptypar Buszost Ven 19 Avr 2024 - 22:56
programmation ECU power vision Dynojet Emptypar Buszost Ven 19 Avr 2024 - 22:45
programmation ECU power vision Dynojet Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
programmation ECU power vision Dynojet Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
programmation ECU power vision Dynojet Emptypar jean-pierre 74 Mer 17 Avr 2024 - 10:43
programmation ECU power vision Dynojet Emptypar Palex Mar 16 Avr 2024 - 22:33
programmation ECU power vision Dynojet Emptypar thierry Mar 16 Avr 2024 - 7:14
programmation ECU power vision Dynojet Emptypar aulo Mar 9 Avr 2024 - 13:09
programmation ECU power vision Dynojet Emptypar Mer14 Mar 9 Avr 2024 - 9:09
vidange synchro garde embrayage huile pneus suis tuto réservoir amortisseur longues tenere crash rabaissement arrière essence feux phare manuel galére carburateur chaine filtre boue reglage fourche
Le Deal du moment : -28%
Précommande : Smartphone Google Pixel 8a 5G ...
389 €
oustad
oustad
Moto : super tenere 1200
Kms de ma moto : 23780
Ville ou région : Metz et Luxembourg
MessageSujet: programmation ECU power vision Dynojet   programmation ECU power vision Dynojet EmptyDim 15 Oct 2023 - 10:54
Voilà, j'ai acheté un boitier power vision dynojet pour flasher l'ECU de ma super tenere 1200
Vendue comme une 2017, c'est en fait une 2016, type mine DP04A06, mais avec un pot akrapovic d'origine, comme à partir de 2017 (je crois).
Le boîtier Dynojet est livré avec une copie de la cartographie (map) d'origine et une cartographie améliorée par eux. (il semble que le boitier n'accepte de flasher l'ECU que si les deux fichiers sont présents, le .stk (stock, c'est à dire origine ) et le .djt (dynojet tuned, réglé par dynojet).
Ca a grandement amélioré le rendu moteur à bas régime. Presque plus d'à coups sur un filet de gaz. En rien plus puissant, mais plus onctueux, c'est ce que je cherchais. Et puis, en me promenant sur le forum US, j'ai trouvé un espagnol qui avait une 2017, qui avait acheté un power vision, et qui avait donc la cartographie de chez dynojet calculée pour le pot akrapovic.
Manque de pot, pas le même type de fichier que moi ( dépend probablement de l'ECU, perso, j'ai un ECU Denso 2BS-8591A-00.
J'ai donc copié collé, grâce au logiciel de chez dynojet, toutes les valeurs de sa map dans le fichier de ma ST.
Et là, c'est presque parfait, coupleux, pas saccadé, onctueux, presque de la vraie Schlagsahne ( les Lorrains comprendront, les germanophones aussi ).
Donc au cas où ça pourrait servir, je tiens à disposition les deux fichiers, l'original et le modifié ( je n'ai pas trouvé comment les mettre en pièce jointe ).
Je récapitule : pour une type DP04A06, ECU 2BS-8591A-00.
Petit rappel, contrairement à la notice dynojet, la prise diagnostique n'est pas sous la selle mais à droite, sous le flanc droit.
D'ici peu, je vais essayer encore une autre cartographie trouvée sur le même forum US, de quelqu'un qui a l'air de savoir modifier une cartographie. Juste pour voir la différence !
Carto du sorcier américain essayé : un régal !
» Philips XTreme ou Blue Vision
» DYNOJET POWER COMMANDER
» Boitier Power commander Dynojet
» phares dditionnels LED vision X
» feux additionnels x vision
