Restauration Super T  XTZ 750 1989 Emptypar hdmanillac Hier à 9:01
Restauration Super T  XTZ 750 1989 Emptypar jean-pierre 74 Lun 13 Mai 2024 - 17:27
Restauration Super T  XTZ 750 1989 Emptypar Mer14 Dim 12 Mai 2024 - 22:13
Restauration Super T  XTZ 750 1989 Emptypar benproof Dim 12 Mai 2024 - 16:33
Restauration Super T  XTZ 750 1989 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Restauration Super T  XTZ 750 1989 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Restauration Super T  XTZ 750 1989 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Restauration Super T  XTZ 750 1989 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Restauration Super T  XTZ 750 1989 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Restauration Super T  XTZ 750 1989 Emptypar oustad Lun 29 Avr 2024 - 19:03
Restauration Super T  XTZ 750 1989 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Restauration Super T  XTZ 750 1989 Emptypar ST44 Sam 27 Avr 2024 - 18:07
Restauration Super T  XTZ 750 1989 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Restauration Super T  XTZ 750 1989 Emptypar meux Ven 26 Avr 2024 - 18:44
Restauration Super T  XTZ 750 1989 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Restauration Super T  XTZ 750 1989 Emptypar MB Mer 24 Avr 2024 - 21:40
Restauration Super T  XTZ 750 1989 Emptypar aulo Mar 23 Avr 2024 - 13:54
Restauration Super T  XTZ 750 1989 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Restauration Super T  XTZ 750 1989 Emptypar Buszost Ven 19 Avr 2024 - 22:56
Restauration Super T  XTZ 750 1989 Emptypar Buszost Ven 19 Avr 2024 - 22:45
Restauration Super T  XTZ 750 1989 Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Restauration Super T  XTZ 750 1989 Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Restauration Super T  XTZ 750 1989 Emptypar Palex Mar 16 Avr 2024 - 22:33
Restauration Super T  XTZ 750 1989 Emptypar thierry Mar 16 Avr 2024 - 7:14
Restauration Super T  XTZ 750 1989 Emptypar aulo Mar 9 Avr 2024 - 13:09
boue embrayage tuto galére amortisseur tenere phare longues rabaissement arrière garde réservoir carburateur reglage vidange synchro huile chaine filtre suis pneus manuel essence feux fourche crash
Le Deal du moment : -21%
39.59 €
Skippercat
Skippercat
Moto : Super Ténéré 750 1989
Kms de ma moto : 41 000
Ville ou région : Toulouse
MessageSujet: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyDim 19 Mai 2019 - 15:12
Bonjour
Voila quelques nouvelles des travaux sur ma moto et retour d'experience notamment sur la carburation.
La moto présentait des problèmes de prise de tour à haut régime, impossible de dépasser 4000 tours.
Nous avons commencer par vérifier la rampe de carbu:
- manchons et membranes fondues! j'avais jamais vu ça, colmaté avec de la pâte à joint
- ressort manquant qui permet d'ouvrir les papillons en même temps... ca risquait pas de bien marcher.
Du coup, changement de la rampe d'occasion, avec nettoyage au bain ultrason
changement des manchons, membranes, joints etc...
J'en profite pour monter le fameux kit suisse avec gicleur plus petits et 2 filtres à air KN.
une fois tout remonté, test avec nourrice d'essence direct sur les carbu... et là... toujours pas possible de monter dans les tours.
Je décide d'aller voir les soupapes... ça se peut qu'elles fuient... pff... les boules, faut démonter le haut moteur, nettoyer, changer les joints etc...
Je remonte je refais une synchro, et en suivant les préconisations constructeur rien y fait... ca monte pas dans les tours toujours avec prise direct sur les carbu pour l'essence.
donc bonne vielle méthode à l'oreille et vis de richesse, plus de 2,5 tours! on y est ca ronronne ouf!
Je repasse par la pompe à essence, neuve acheté au japon à moitié prix. et la ça veut plus!
Je refais des tests mais surtout, je remonte les filtres à air d'origine... et hop... c'est reparti, la ça tourne parfaitement.
Moralité, avec le kit suisse, faut pas trop faire de modif, régler la richesse et c'est bon, les KN rangés dans leur boite.
A ce stade:
- rampe de carbu: 40 euros d'occasion
- pompe Yamaha (110 euros chez IMPEX)
- mambranes de boisseaux (22,08€ chez Kedo)
- pipes d'admissions(18,90€ chez 3AS)
- kit joints carbu (21€ chez 3AS)
- Kit joints haut moteur (87 € chez 3AS)
- Kit crabu (66,50 € chez kedo) => fameux kit suisse)
- puits d'aiguilles ( 15 € chez Kedo)
- manchons (20€ chez je sais plus qui)
A préciser que j'ai pas fait ça tout seul, mais avec l'aide précieuse d'un mécano qui a su diagnostiquer et régler à l'oreille, (ancien chef d'atelier Yamaha). Merci Jeff t'es une bête du diag!
Voila, ça tourne mais y'a encore du boulot, vidange, freinage, fourche avant vraiment trop souple, pneu avant, selle, et déco!
Skippercat!
Borgil
Borgil
Kms de ma moto : 89000
Ville ou région : Grenoble
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyDim 19 Mai 2019 - 18:54
Content de voir que tu t'en est sorti. J'ai eu la même appréhension en démontant la mienne, mais aucun mécano sous le coude.
Pour l'instant, je touche du bois, ça tiens. Mais j'ai passé des heures à écumer les sujets sur le kit suisse pour faire mon propre kit (gicleurs principaux en 137.5, ralenti en 35, et aiguilles d'origine) avec le bon réglage de richesse tout de suite (3 tours, quand certains montent à 3.5)
Idem, changé tous les joints sur les 2 carbus pour être tranquille (et parce que l'un d'eux fuyait)
J'ai actuellement une batterie HS ce qui m'empêche de faire des essais plus long, mais je la reçois dans la semaine et devrait pouvoir tout valider. Mais après avoir démarré à la poussette plusieurs fois, et fait le tour du quartier, ça semble bon.
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyDim 19 Mai 2019 - 19:07
Salut Borgil,
pas encore tester sur un plein car il me reste quelques travaux
de sécurité... Mais j'y crois, si déjà tout tourne normalement, y plus que la console à vérifier!
bon courage
barra
barra
Kms de ma moto : 89 000
Pneu AV/AR : anakee III
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 24 Mai 2019 - 14:33
j ai fait cette modif ,il y a un an ..et 10 000 km ....
la moto tourne nickel ,demarre tous les jours ,pour aller bosser ..quand il fait beau ...
j ai fait un plein hier ...
16.6 pour 320 km .....
les chiffres parlent d eux meme !
5.2 l au 100
petites routes 100 a 120km/h ,pas plus ,mais sans me trainer non plus
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyLun 17 Mai 2021 - 13:51
Restauration Super T  XTZ 750 1989 Img_0915
Restauration Super T  XTZ 750 1989 Img_0916Restauration Super T  XTZ 750 1989 Img_0915
Restauration Super T  XTZ 750 1989 Img_0917
alors voila, j'ai fait simple:
- changement du MC avec un radial diam 16 (La becannerie) =80€
- Durite avia chez Yam=70€
- rénovation des étriers =80€ (joints+ piston) chez Kedo
- plaquettes metal frité=20€
- huile de fourche un poil plus épaisse
- purge du circuit ca va sans dire.
Ca freine pas mal, la fourche plonge moins. le toucher du frein est meilleur, plus moderne. Bon faut pas s'attendre à un freinage de GSXR avec des petits disque, mais c'est mieux.
Y'a encore pas mal de boulot à venir.
Skippercat
Thibs
Thibs
Kms de ma moto : 80.000
Ville ou région : jurbise
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptySam 3 Juil 2021 - 19:40
Hello,
Alors du nouveau sur ta super T, as tu des photos lors du démontage HM ou même de l'ensemble ?
Le forum se déserte j'ai l'impression et s'est bien dommage   Restauration Super T  XTZ 750 1989 1f615
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyMar 6 Juil 2021 - 22:08
Salut Thibs,
oui un peu avancé
- selle  (Argentine + sellier local- 130€)
- clignotants led et relay (Amazon -25€)
- Regulateur (Angleterre - 80€)
- Kit Chaine (DID hez Kedo 110€)
- plaque anti chaleur sur les collecteur d'echappement (KEDO - 16€)
- SAblage collecteur (local - 30€) + peinture haute temperature à la bombe 16€)
- coffre sous selle (30€ le boncoin)
- patin de bras oscillant + celui du dessous (30€ Leboncoin)
- ampoules H4 philips hautes performances (16€ norauto)
- nettoyage du comodo gauche WD40 (c'est mieux avec une bombe pour contact électronique mais ca marche quand même)
- pontets reculés (LSL 60€), je suis pas a l'aise avec les autres neufs chez SW qui sont juste plus haut
Je vais changer le joint du cache culbuteur par un origine Yamaha, l'autre est neuf de chez Tourmax mais il fuit).
J'ai aussi un pbl d'alternateur qui va falloir changer je pense (pas de charge, et mauvaises tensions sur un des circuits...)
Voila encore du taff parce que j'ai pas fini de tout monter mais bientot la déco et les ballades, j'en ai marre de bricoler et de rater les sorties avec les copains!
Merci pour ton message
Skippercat
Restauration Super T  XTZ 750 1989 Super_10[url=https://servimg.com/view/20339891/10]Restauration Super T  XTZ 750 1989 Super_11[url=https://servimg.com/view/20339891/11]Restauration Super T  XTZ 750 1989 Super_12[/url][/url]
Borgil
Borgil
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyMer 7 Juil 2021 - 9:43
Wow, la selle est MA-GNI-FIQUE !!!
A voir avec la peinture que tu vas faire, mais ça donne un rendu de dingue.
Pour le reste, joli boulot. J'aimerai bien trouver quelqu'un par chez moi qui me ferai un sablage du collecteur pour si peu cher aussi...Car j'ai beau l'avoir brossé, ça donne pas du tout un résultat bien génial.
En tous cas ouais, dépêche toi d'en profiter et nous raconter !
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 8 Juil 2021 - 19:34
Merci Borgil,
j'ai mis beaucoup de temps pour trouver une housse sympa. J'ai trouvé celle la top, de très bonne qualité chez un fabricant de selles cross en Argentine. C'est un peu cher a cause du transport mais ca a de la gueule.
J'ai fait posé par un sellier car les cotes sont un poil justes (50€) je ne voulais pas me louper, l'Argentine c'est pas à coté pour aller en chercher une autre Smile. Il a un peu retravaillé la mousse d'origine en creusant coté pilote de 2cm (à ma demande) et en arrondissant les bords pour avoir une meilleur coupe avec les coutures de la housses bien alignées. Comme ca ca fait pas mal au cul quand t'es en maillot de bain Smile.
Faudrait peut-etre lancer un sujet sur cette housse selle pour voir si d'autres membres sont intéressés, je pourrai en faire venir par un autre moyens et du coût ce serai beaucoup plus intéressant. Mais pour ca il en faudrait une bonne 20ene.
Qu'en dis tu?
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 8 Juil 2021 - 19:38
pour le sablage tu as des boites vers chez toi. Franchement ils y passent 10 minutes... plus chers que 30€ c'est du vol, surtout si tu amène le collecteur propre (dégraissé).
Decap'Colors et SMP Sablage.
Borgil
Borgil
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 9 Juil 2021 - 9:51
J'en dit que trouver une vingtaine de personnes intéressées ici, ça sera mission impossible ^^
Nous ne sommes plus si nombreux à posséder ce bon vieux 750, et encore moins à être là de manière régulière. Donc...
Mais merci pour les infos ;)
Pour la sablage, j'essaierai de me renseigner ouais, quand j'aurai un peu filtré mes autres priorités
Thibs
Thibs
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyMer 28 Juil 2021 - 22:00
Effectivement, le forum 750 se fait vraiment calme 🙁
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 29 Juil 2021 - 19:08
Je crois que Facebook a pris le dessus...
Hubert Gaudriole
Hubert Gaudriole
Moto : EX : 750 ZEPHYR 1200 ZRX 955 SPRINT ST 900XJ 1200FJ 900 SMT R 1200 S RF 900 R 1000 VTR Actuelle 750 XTZ 89 FARADAY BLUE
Kms de ma moto : 46 000 km
Pneu AV/AR : Mitas terraforce r
Ville ou région : Clermont-Ferrand Auvergne
MessageSujet: restauration 750 Super Ténéré 1989    Restauration Super T  XTZ 750 1989 EmptySam 21 Aoû 2021 - 7:41
Salutations d'Auvergne les gars
Juste pour pour dire que je lis vos post une mine d'or pour moi , plein d'info et d'idée très intéressantes
Il faut faire vivre ce forum 750
Les anciennes resterons .....
sus à l'électrique, l'électronique
dgedenice
dgedenice
Moto : XTZ 750 super tenere
Kms de ma moto : 58000
Ville ou région : Nice
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 3 Sep 2021 - 0:40
Slt, ne lachez rien, je vous suis depuis Nice et japprend a chaque lecture.
Hubert Gaudriole
Hubert Gaudriole
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 3 Sep 2021 - 7:28
Facebook , twitter , WhatsApp et consorts
BEURK les gens sont malades au Sens propre sur ces trucs
Rien ne vaut un bon forum et un club de moto sympa pour ballade , off road et road Trip
En panne tu tomberas, dépanner tu essayeras, pousseras tu pleureras, à pied tu iras.
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyMer 22 Sep 2021 - 17:50
Salut les persévérants!
Je détère ce sujet car il y a déja eu des posts là dessus sur les solutions mais pas sur le retour d'experience de ce qui a été mis en place.
Je suis devant une panne avec filetage mort sur l'axe de sortie de boite. le pignon avait été monté à la sauvage par l'ancien proprio avec des coups de pointeau...bref du coup changement de kit chaine impossible...
J'ai essayé de fileter de nouveau avec une filière de 18/100 et un outils que j'ai fabriqué.
Malheureusement le filetage est trop abimé et même comme ca ca ne tient pas.
Est-ce qu'au final vous avez pu faire ce montage en percant l'arbre + filetage? Si oui est-ce que ca tient? et surtout est-ce que qqun à récupéré ces plans?
Enfn, je me demande si je ne vais pas décendre le diamètre pour filer à 17/100, restera plus d'à fabriquer uen entretoise et trouver un ecrou de 17...
Qu'en pensez vous?
Skippercat
Thebestroll
Thebestroll
Ville ou région : Sarrebourg
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 23 Sep 2021 - 23:03
Perso je dirais ”changer l’arbre de sortie de boite” par un autre en BE. Voir tout le bas moteur, au choix.
C’est que ca se remplace souvent un kit chaine!!
Y en a des qui soudent l’ecrou, voir le pignon, et qui revendent la moto vite fait..........
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 24 Sep 2021 - 8:49
Oui c’est sûr c’est le mieux mais vu le boulot... je vais choisir la solution la plus propre avec un perçage taraudage de l’arbre au centre. Je mettrai des photos/plans.
Merci!
Borgil
Borgil
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 24 Sep 2021 - 9:45
Merci!
Je n'en ai pas besoin pour l'instant, mais avec tous les coups de pute qu'elle m'a fait, possible que ça arrive.
Donc très intéressé par ton partage Smile
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 6 Jan 2022 - 17:21
Bonjour bonjour,
Il me tardait d'écrire ce post!
Après m'être inspiré des plans de Fabien43770 (merci encore), j'ai simplifié le montage et fait fabriquer la pièce chez un tourneur local.
La pièce est en acier, et ce n'est pas tout à fait les même côtes mais pas loin.
Il n'y a plus qu'une pièce et la vis.
Pour le perçage de l'axe, il faut être bien droit donc j'ai fait faire un guide de perçage dans le même acier (qui se pose sur la dite pièce avec un trou de 6) comme ca la mèche pose dessus en quelque sorte.
A ce propos, l'acier de l'arbre est traité donc les forets acier que j'avais je perçais pas, par contre celui au carbure, trop facile.
Ensuite il faut tarauder délicatement et voila!
Cout de la pièce et du guide 50€
cout du foret carbure 17€
j'avais les tarauds mais sinon compter dans les 20-30€ selon les modèles.
la pièce serre bien le pignon de sortie, y 'a plus qu'à voir a la longue, je vous dirait ca.
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyJeu 6 Jan 2022 - 17:22
Restauration Super T  XTZ 750 1989 Img_1712
Restauration Super T  XTZ 750 1989 Img_1713
Borgil
Borgil
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptyVen 7 Jan 2022 - 10:19
Ah joli ! Et pas cher finalement, surtout pour sauver un moteur.
Tu aurai la gueule du guide aussi qu'on se fasse une meilleur idée de comment tu as fait stp ?
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptySam 8 Jan 2022 - 20:13
Restauration Super T  XTZ 750 1989 Img_1911[url=https://servimg.com/view/20339891/21]Restauration Super T  XTZ 750 1989 Img_1912
[/url]
Skippercat
Skippercat
MessageSujet: Re: Restauration Super T XTZ 750 1989   Restauration Super T  XTZ 750 1989 EmptySam 8 Jan 2022 - 20:14
c'est un cylindre pliein qui se positionne dans le prolongement de la piece, juste posé dessus, percé au diametre du foret. Simple mais efficace.
» Restauration XTZ 750 Super T
» Super Tenere 1989
» Restauration super T de 1990
» Restauration Super-Ténéré 750
» RESTAURATION XTZ 750 super tenere Saunoto
