FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar hdmanillac Hier à 9:01
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar jean-pierre 74 Lun 13 Mai 2024 - 17:27
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Mer14 Dim 12 Mai 2024 - 22:13
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar benproof Dim 12 Mai 2024 - 16:33
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar REYNALD Lun 6 Mai 2024 - 17:08
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar REYNALD Lun 6 Mai 2024 - 17:06
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Mich77 Dim 5 Mai 2024 - 11:08
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar oustad Lun 29 Avr 2024 - 19:03
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar ST44 Sam 27 Avr 2024 - 18:07
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar meux Ven 26 Avr 2024 - 18:44
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar REYNALD Ven 26 Avr 2024 - 11:53
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar MB Mer 24 Avr 2024 - 21:40
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar aulo Mar 23 Avr 2024 - 13:54
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar yop1025 Lun 22 Avr 2024 - 20:30
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Buszost Ven 19 Avr 2024 - 22:56
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Buszost Ven 19 Avr 2024 - 22:45
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar Palex Mar 16 Avr 2024 - 22:33
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar thierry Mar 16 Avr 2024 - 7:14
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Emptypar aulo Mar 9 Avr 2024 - 13:09
phare feux rabaissement suis tuto synchro essence amortisseur embrayage fourche manuel garde pneus galére tenere arrière huile boue réservoir chaine reglage crash filtre vidange longues carburateur
stretchie
stretchie
Moto : Super Ténéré
Kms de ma moto : 70000
Ville ou région : Brive
MessageSujet: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptySam 14 Juil 2018 - 17:50
Salut les motards, je m'approche de vous car je suis propriétaire d'un xtz et récemment d'un 850 tdm 4 tx.
Sur ce dernier, après un nettoyage a la cuve a ultrason du carbu, j'ai le carbu qui pisse par différent endroit.
Ayant vérifier les aiguilles, les plongeurs et cuves, je ne vois rien de suspect. Je n'arrive pas à comprendre pkoi ca pisse par ces trous (zones entourées en rouge) et par le té d'arrivée d'essence.
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Fuite_carbu
Si quelqu'un connaitrait ce soucis car là ca fait 2 jours que je suis dessus et j'en peux plus là.
Merci les motards
Luc
jose84300
jose84300
Moto : xtz 750
Kms de ma moto : 47000
Pneu AV/AR : mitas E10
Ville ou région : CAVAILLON
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptySam 14 Juil 2018 - 18:29
salut , avez tu démontez complètement tes carbu et viré tout ce qui pouvait être en plastique ou joint  . Parce que selon le produit utilisé pour le nettoyage  ça peu crée quelques souci . ex : j'ai fait les miens a la javel pour briller ça brille mais ce matin les papillons bloqué de chez bloqué, bon un peu de w40 et tout est rentré dans l'ordre .mais quelque fois on pense bien faire et ça ce passe pas comme on veux . a par de tout démontée et vérifié voir changé si nécessaire je sais pas quoi te dire c'est quand même bizarre
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptySam 14 Juil 2018 - 18:58
Ben j'ai utilisé un produit spécial pour mécanique et cuve. De mon côté, rien ne semble bloqué.
J'avais juste enlever membranes, aiguilles et cuve + poiteaux. J'ai rien démonter de +
Luc
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptySam 14 Juil 2018 - 21:57
Les cuves se remplissent à fond et les pointeaux ne ferment pas; L'essence continue d'arriver au delà du niveau normal lorsque les flotteurs remontent... S'ils remontent ...
Plusieurs causes possibles:
-les flotteurs sont crevés et ne flottent plus.
-les flotteurs grippent sur les axes ou ne sont pas montés correctement .
-les pointeaux grippent sur les parois des puits et coulissent mal dans leurs logements; ils empêchent ainsi la remontée du flotteur.
-Les pointes des pointeaux ferment mal sur leurs sièges .
 Il arrive également qu'il y ait des durs mécaniques au niveau du contact pointeau-flotteur qui font que le pointeau ne glisse pas sur le flotteur à cet endroit pendant le mouvement de ce dernier .
Les aiguilles, les guillotines et les membranes sont hors de cause .
En tout cas ....Ca brille !!
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyDim 15 Juil 2018 - 0:00
Merci de ta réponse. Je suis très surpris de ta réponse car les flotteurs et pointeaux sont les premiers éléments que j'ai contrôle et franchement, les pointeaux sont nickel et les cuves remontent bien. Bizarre
jose84300
jose84300
Moto : xtz 750
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyDim 15 Juil 2018 - 8:02
pour voir si ça viens des flotteurs ou pointeaux ,essai avec un petit tuyau de faire le niveau de tés cuves
.tu trouvera comment faire sur ta rtm,de mémoire cela doit reste entre 5 et6 si ça déborde de ton tuyau tu a ta panne
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyDim 15 Juil 2018 - 12:09
 La méthode est bonne mais arrivé à ce stade, je pense que ça n'est même pas la peine; le niveau monte au max forcément puisque ça déborde .
Il y a forcément un truc qui coince là dedans mais reste à savoir quoi ...Je ne connais pas spécialement les carbus des 750, mais les 2 flotteurs sont ils identiques, et, dans le cas contraire n'y a t'il pas un détail qui fait qu'on ait pas le droit de les croiser ?
Au niveau du contact pointeau- flotteur , y a t'il un montage avec une agrafe ?
Je me suis vu aussi un jour à devoir polir l'intérieur des puits de pointeaux avec du miror et un coton tige parce que le pointeau coulissait mal... C'est du réglage "fin de chez fin".
N'y a t'il pas moyen d'inverser la position des durites avec une autre entrée sur les carbus ?
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyDim 15 Juil 2018 - 17:34
Hello, non je crois que je vais acquérir un carbu d 'occaz parce que là l 'été a commencé et ca me gave Smile
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyLun 16 Juil 2018 - 8:05
Es tu certain que tu ne t'es pas planté au niveau des entrées de l'arrivée d'essence (j'insiste) .En regardant la RT je me rends compte qu'il y a deux T de raccordements qui ne sont pas loin l'un de l'autre et , sur la photo, la fuite en haut me paraît étrange :!
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyLun 16 Juil 2018 - 10:59
Ben sur ma RTA et sur le carbu, y a qu'un seul té d alimentation qui dessert sur les 2 carbus. J'ai commandé un carbu d'occasion et je vous tiens au courant des que je le recois.
Bonne semaine
Luc
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyMer 18 Juil 2018 - 13:27
Salut à tous, je reviens vers vous suite à des problemes de fuites et je me demande si ce n'est pas plutot de branchement. La RTA que j'ai ne montre pas les connectiques d'un 4tx mais d'une version plus ancienne alors je me paume.
Pouvez vous me dire si ya une durite qui se branche sur l'embout face à la flèche rouge et si oui quelle durite ?
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Fuite_carbu2
merci de votre aide
Luc
oufrider2728
oufrider2728
Moto : xtz 750
Kms de ma moto : 540000
Ville ou région : Normandie
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyMer 18 Juil 2018 - 14:34
Pour moi ta fleche rouge est l'arrivée d'essence et là ou la durite est branché est une mise a l'air ( comme sur les carbu de 750 ST de mémoire )
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyMer 18 Juil 2018 - 14:55
merci de votre aide
Luc
:(:bonjour:Ta reponse est là.  https://www.ouestlekeum.com/forum/moteur/848-refection-moteur.html
FUITE CARBU APRES PASSAGE CUVE A ULTRASON Dfzl10
stretchie
stretchie
Moto : Super Ténéré
MessageSujet: Re: FUITE CARBU APRES PASSAGE CUVE A ULTRASON   FUITE CARBU APRES PASSAGE CUVE A ULTRASON EmptyMer 18 Juil 2018 - 15:45
Hello, oui j'ai testé c'est bien ca les gars. Merci grandement Smile
Luc
» aie aie aie cuve de carbu!!!
» DEMARRE PLUS APRES POSE "KIT SUISSE" CARBU
» Fuite essence carbu XTZ 750
» Fuite Essence alimentation du carbu
» fuite au carbu 750 super tenere de1991
