Vidange fourche XTZ 1200 - Page 2 Emptypar jean-pierre 74 Hier à 17:27
Vidange fourche XTZ 1200 - Page 2 Emptypar Mer14 Dim 12 Mai 2024 - 22:13
Vidange fourche XTZ 1200 - Page 2 Emptypar benproof Dim 12 Mai 2024 - 16:33
Vidange fourche XTZ 1200 - Page 2 Emptypar REYNALD Lun 6 Mai 2024 - 17:08
Vidange fourche XTZ 1200 - Page 2 Emptypar REYNALD Lun 6 Mai 2024 - 17:06
Vidange fourche XTZ 1200 - Page 2 Emptypar Mich77 Dim 5 Mai 2024 - 11:08
Vidange fourche XTZ 1200 - Page 2 Emptypar petitlutin Jeu 2 Mai 2024 - 12:34
Vidange fourche XTZ 1200 - Page 2 Emptypar yannick 63 Mar 30 Avr 2024 - 22:41
Vidange fourche XTZ 1200 - Page 2 Emptypar oustad Lun 29 Avr 2024 - 19:03
Vidange fourche XTZ 1200 - Page 2 Emptypar Pzc29 Lun 29 Avr 2024 - 10:33
Vidange fourche XTZ 1200 - Page 2 Emptypar ST44 Sam 27 Avr 2024 - 18:07
Vidange fourche XTZ 1200 - Page 2 Emptypar hdmanillac Ven 26 Avr 2024 - 19:21
Vidange fourche XTZ 1200 - Page 2 Emptypar meux Ven 26 Avr 2024 - 18:44
Vidange fourche XTZ 1200 - Page 2 Emptypar REYNALD Ven 26 Avr 2024 - 11:53
Vidange fourche XTZ 1200 - Page 2 Emptypar MB Mer 24 Avr 2024 - 21:40
Vidange fourche XTZ 1200 - Page 2 Emptypar aulo Mar 23 Avr 2024 - 13:54
Vidange fourche XTZ 1200 - Page 2 Emptypar yd64 Mar 23 Avr 2024 - 8:34
Vidange fourche XTZ 1200 - Page 2 Emptypar yop1025 Lun 22 Avr 2024 - 20:30
Vidange fourche XTZ 1200 - Page 2 Emptypar Buszost Ven 19 Avr 2024 - 22:56
Vidange fourche XTZ 1200 - Page 2 Emptypar Buszost Ven 19 Avr 2024 - 22:45
Vidange fourche XTZ 1200 - Page 2 Emptypar Chicken2525 Ven 19 Avr 2024 - 14:32
Vidange fourche XTZ 1200 - Page 2 Emptypar Johnparalot Mer 17 Avr 2024 - 21:44
Vidange fourche XTZ 1200 - Page 2 Emptypar Palex Mar 16 Avr 2024 - 22:33
Vidange fourche XTZ 1200 - Page 2 Emptypar thierry Mar 16 Avr 2024 - 7:14
Vidange fourche XTZ 1200 - Page 2 Emptypar aulo Mar 9 Avr 2024 - 13:09
manuel reglage vidange boue garde synchro carburateur suis phare embrayage longues réservoir feux arrière crash essence tenere galére rabaissement pneus huile tuto fourche amortisseur filtre chaine
Funko POP! Jumbo One Piece Kaido Dragon Form : où l’acheter ?
Le Deal du moment : -21%
39.59 €
Tamasheq
Tamasheq
Moto : ex Super Ténéré ZE
Pneu AV/AR : TKC 70
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMar 18 Avr 2017 - 19:22
Très beau tuto !
Merci (mais pas pour moi, j'ai une ZE et je dois être un peu plus trapu et surtout cela dépasse ce que je me risque à faire ;-))
Tamasheq
etinag
etinag
Pneu AV/AR : Cramponnés
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMer 19 Avr 2017 - 10:12
@dédé
Tu n'a pas pensé à mesurer les ressorts ?
J'ai remplacé fourche et amorto ( j'avais stocké ça à l'état quasi neuf) il y a une quinzaine de jours et ma grosse a retrouvé +3cm . Impressionnant ...
Je vais reconditionner l'ancienne fourche mais j'aurai voulu comparer les cotes avec d'autres ;-)
Elle n'a que 55000 bornes mais pas mal de TC et un peu de TT donc ça souffre un peu plus niveau suspattes.
lacaille
lacaille
Moto : XT1200Z 2011
Kms de ma moto : 45000
Pneu AV/AR : Tourance Next
Ville ou région : Yonne
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyLun 15 Jan 2018 - 19:41
une t'ite question... serait il possible de balancer un produit quelconque (pétrole, wd40...) dans le fond du tube de fourche pour enlever les résidus et bien nettoyer/rincer l'intérieur.
ça éviterait,ainsi, d'avoir à démonter les tubes plongeurs!
édit: je viens de lire sur un forum que certains utilisaient du kerdane (pétrole désaromatisé) qui n'est pas un solvant donc pas agressif pour les joints...
Vidange fourche XTZ 1200 - Page 2 Signat13
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyLun 15 Jan 2018 - 20:54
Tu t'embêtes bien; le manuel d'atelier ne précise rien déjà au niveau de l'entretien de la fourche tant qu'il n'y a pas de suintements ou d'autre problème; les concessionnaires préconisent d'y regarder vers 40000; pourquoi pas ? mais de là à balancer là dedans des produits qui sont tout de même anti lubrifiants, c'est bien chercher le bâton ! On fait déjà de la surmaintenance, on retourne en plus les tubes pour les vider, c'est peut être pas la peine d'en rajouter ...
Moto : XTZ 2014 ES
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyLun 15 Jan 2018 - 21:32
Au pire, une huile de fourche très fluide (W2.5), tu fais aller ta fourche plusieurs fois pour faire passer l'huile partout et nettoyer les clapets, une vidange, et tu remets l'huile conforme a celle d'origine.
- Non, mais c’était prévu.
lacaille
lacaille
Moto : XT1200Z 2011
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMar 16 Jan 2018 - 7:25
merci pour vos avis Smile
je te l'accorde @Dédé, c'était une réflexion que je me faisais car je ne voyais pas l'utilité de démonter le tube plongeur (d'autant qu'il faut fabriquer un outil...) et vu que les autres opérations (changement des bagues /joints) peuvent se faire sans...
d'ailleurs, à quoi sert de démonter la fourche entièrement!???
je retiens ta solution @caillou bien
Remph
Remph
Moto : XT600 - XTZ 1200
Kms de ma moto : 70 000
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptySam 7 Avr 2018 - 16:19
Petit retour d'expérience.
À deux, c'est mieux. Smile
L'outil utilisé.
Vidange fourche XTZ 1200 - Page 2 20180413
Compression avec sangle à cliquet
Vidange fourche XTZ 1200 - Page 2 20180416
Vidange fourche XTZ 1200 - Page 2 20180415
Du fil électrique pour tenir la pipe d'amortissement lors du remontage.
Vidange fourche XTZ 1200 - Page 2 20180414
Je n'ai pas démonté totalement la fourche. Objectif: faire simple et changer joints spi, cache poussière, huile.
Les caches poussières commandés sur wemoto n'étaient pas totalement adaptés ni même de la même forme.
Adaptation et maintien avec du ruban au téflon et scotch étanche. Les joints spi étaient mis en place lors du constat de la différence des cache poussière, donc trop tard de toute façon. Référence à éclaircir, je vais voir avec wemoto pour que quelqu'un d'autre ne se fasse pas "avoir".
Je viens de percuter que je n'ai pas mesuré la longueur des ressorts, on verra bien la prochaine fois.
Merci encore pour cet excellent sujet !
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptySam 7 Avr 2018 - 21:22
Les ressorts???  Et tu vas mesurer quoi ?   Leur affaissement éventuel ....à 35000 km... Tu plaisantes ?
Remph
Remph
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptySam 7 Avr 2018 - 21:28
Je vérifie qu'il y a toujours autant de spires. cool
Non, je mesure pour "savoir". Ne serait-ce que pour comparer avec la valeur d'origine. À 43k km sans énormément de TT (ou plutôt TC), ils sont sans nul doute encore largement dans les côtes.
Leplep60
Leplep60
Kms de ma moto : 59175
Ville ou région : Normandie
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptySam 7 Avr 2018 - 21:56
L'enseignement de la manip, plus que les ressorts (qui semblaient en fort bon état), c'est que l'huile méritait d'être changée. Spi neufs, caché poussière neufs, huile changée, et bientôt étriers nettoyés.
Les deux spi devaient être changés, et je dirais tant mieux car tu repars avec une huile neuve dans les deux tubes, ce qui évitera une dissymétrie.
Ça fait du bien à ta moto, et tu devrais voir une amélioration. Essai à suivre ...
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 8 Avr 2018 - 7:38
Ce qui est surtout très important, c'est de serrer les tubes sur les tés de fourche au couple préconisé, pour qu'en cas de chute la fourche puisse vriller juste quand il le faut mais pas trop tôt non plus; j'ai eu le cas dans une chute à l'arrêt, je me suis retrouvé avec le guidon de travers; visite à la concession la plus proche où le mécanicien m'a expliqué cela ; il a suffi de tout desserrer et tout s'est remis en ligne; si c'est trop serré, les tubes peuvent se tordre ; en revanche, il ne faut pas rester trop longtemps dans la mauvaise position car les coulissements internes travaillent en force et les bagues morflent .
babu80
babu80
Pneu AV/AR : Metzeler
Ville ou région : Périgord
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 26 Mai 2019 - 13:47
Bonjour;
je reprend ce post après avoir un peu galérer et balancer suffisamment de nom d'oiseau pour le remontage;
J’ai décider de changer les ressort d'origine par des  ressort progressif de chez wilbers; faire la vidange et changer les joints spi;
donc j'ai fabriquer l'outil  censée permettre le démontage et remontage.avec les bonnes cote
pour le démontage aucun problème, mais lors du remontage... un os comme tu est seul personne pour t'aider, avec un ressort légèrement, . plus long mais surtout plus dure , impossible de le comprimer suffisamment pour revisser le bouchon  avec la tige de la pipe d'amortissement, sans que le ressort finisse par se mettre en travers He hop tu t'agace grave après 10 tentative;
j'ai donc modifier l'outil en le rallongeant; ce qui permet de se servir du fourreau pour guider  l'outil afin de pouvoir comprimer le ressort en toute sécurité.
 pour éviter de voir descendre le fourreau par inertie, j'ai mis un collier riseland  sur le tube de fourche afin d'avoir les mains libre;
Et comme on est presse on fait une connerie LOL lors du 2eme fourreau par sécurité j'avais sorti la tige alu qui rentre dans la pipe d’amortissement  pour ne pas l'abimé  , javais tout remonter roue étrier et cetc bref tout hé là surprise GRRRRRRRRR
en 30 minutes Redémonté et tout remonté
Vous pouvez voir le premier outils  sur la partie supérieur t la modif faite après en fait l'outil fait 8cm de long au lieu des 4 d'origine
babu80
babu80
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 26 Mai 2019 - 13:55
Vidange fourche XTZ 1200 - Page 2 P_201917
Vidange fourche XTZ 1200 - Page 2 P_201918
Vidange fourche XTZ 1200 - Page 2 P_201919
babu80
babu80
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 26 Mai 2019 - 13:57
Vidange fourche XTZ 1200 - Page 2 P_201920
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMer 29 Mai 2019 - 11:41
Il y en a pas beaucoup qui se sont lancés eux mêmes dans cet entretien. Merci pour le partage, ça donne des idées.
davidsuperT
davidsuperT
Moto : xt1200ze2017
Kms de ma moto : 73000
Pneu AV/AR : mi road 6 trail av/ar
Ville ou région : ville en waret
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMer 19 Aoû 2020 - 13:12
Bonjour à tous , je cherche juste l'info pour la capacité d'huile des canons de fourches
pour une ST de 2017 ZE et la hauteur du niveaux d'huile de ceux ci .
je trouve les info pour les plus anciennes , mais je ne serais pas étonné d'une différence pour les derniers modèles .....
( j'ai eu info de mon concess , qui m'annonce 505cc canon gauche et 493 cc canon droit )
si vous avez des infos , je suis preneur .
merciiiii
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMer 19 Aoû 2020 - 14:06
merciiiii
Ton concess dit vrai.
Il doit rester 148mm entre le niveau d'huile et le sommet du fourreau (comprimé à fond et sans le ressort ni son guide).
davidsuperT
davidsuperT
Moto : xt1200ze2017
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMer 19 Aoû 2020 - 14:11
super, merci Yolosef , et good ride à tous .
JC
JC
Moto : YAMAHA XTZ 1200 SUPER TÉNÉRÉ 2012
Kms de ma moto : 40000
Pneu AV/AR : Michelin Anakee Adventure
Ville ou région : Rumilly
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMar 8 Juin 2021 - 11:25
je relance ce sujet avec une question :
Je souhaite renouveler l'huile de fourche sur ma XT1200Z, en démontant le moins de composants possibles.
Que pensez-vous de la méthode donnée par Dave Moss, ci-après :
Le principe est simple, Dévisser le tube, ne pas démonter le ressort, vider toute l'huile possible, en pompant à plusieurs reprises.
Mesurer précisément la quantité d'huile retirée puis remettre la même quantité.
Qu'en pensez-vous ?
Merci d'avance pour vos réponses éclairées.
JC
THORE Patrick
THORE Patrick
Moto : 1200 XTZ worldcrosser
Kms de ma moto : 22000
Ville ou région : Esquelbecq (59470)
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMar 1 Mar 2022 - 9:41
Beau tuto, je m'en suis inspiré pour remplacer mes joints spy et faire ma vidange de fourche.
Par contre concernant l'outil pour comprimer le ressort, j'ai fabriqué un collier en 2 parties qui correspond au diamètre de la bague épaulée en plastique blanc(le collier fait donc environ 32mm intérieur)le collier appuie directement sur le ressort .Vidange fourche XTZ 1200 - Page 2 20220211
Vidange fourche XTZ 1200 - Page 2 20220212
Vidange fourche XTZ 1200 - Page 2 20220210
jeromec30
jeromec30
Moto : 1200 xtz
Ville ou région : Occitanie
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyJeu 12 Jan 2023 - 15:20
Déterrage de post.
Un grand merci pour ce super tuto.
Remplacement bagues, joints fabrication de l'outil.
Nickel.
banditos
banditos
Moto : XTZ 1200 World Crosser
Kms de ma moto : 67000
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 2 Avr 2023 - 13:02
j'avais pas remercié le 1ère fois donc je le fais, merci pour ces infos.
Je viens de refaire mes joints à 63000 bornes.
Une photo de la bête en pièces détachées.
Vidange fourche XTZ 1200 - Page 2 20230416
Gengoux
Gengoux
Moto : xtze1200
Kms de ma moto : 65000
Ville ou région : Tubize, Belgique
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyMar 4 Avr 2023 - 12:15
Vous avez une idée de ce que pourrait me coûter le reconditionnement de la fouche avant ? Je parle de remplacer l'huile, les joints etc.. A 65000km je trouve les suspates très molle.
Je ne me sens pas du tout capable de le faire moi-même.
Merci d'avance.
banditos
banditos
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 9 Avr 2023 - 18:39
Salut à tous, je viens de faire mes joints spi avec changement des bagues.
Je mets quelques photos de mes outils ainsi qu'un lien du fichier d'impression 3d que j'ai dessiné pour imprimer un outil pour insérer le joint.:
Outil de maintien de vérin (vieux guidon de trottinette coupé)
Vidange fourche XTZ 1200 - Page 2 20230418
Outil pour compresser le ressort
Vidange fourche XTZ 1200 - Page 2 20230419
banditos
banditos
MessageSujet: Re: Vidange fourche XTZ 1200   Vidange fourche XTZ 1200 - Page 2 EmptyDim 9 Avr 2023 - 18:43
J'ai oublié,
Outil pour insérer le joint (IMP 3d)
Vidange fourche XTZ 1200 - Page 2 Outil_10Vidange fourche XTZ 1200 - Page 2 Outil_11
Durite pour maintenir la tige du vérin
Vidange fourche XTZ 1200 - Page 2 20230420
» Vidange fourche 1200 xtz
» Vidange fourche XTZ 1200
» VIDANGE Fourche XTZE
» Vidange fourche Xtz 600 3aj
