GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar oeuf Aujourd'hui à 10:11
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar oeuf Aujourd'hui à 10:03
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar Joe644 Mer 20 Nov 2024 - 18:56
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar yop1025 Mer 20 Nov 2024 - 13:10
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Mar 19 Nov 2024 - 10:58
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Mar 19 Nov 2024 - 10:49
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Mar 19 Nov 2024 - 10:46
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Mar 19 Nov 2024 - 10:44
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar jackal74 Lun 18 Nov 2024 - 11:58
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar Arni Dim 17 Nov 2024 - 14:06
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar Arni Dim 17 Nov 2024 - 13:13
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar yop1025 Sam 16 Nov 2024 - 23:12
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar Fredard Sam 16 Nov 2024 - 9:43
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar J-Marc Mar 12 Nov 2024 - 12:44
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar J-Marc Lun 11 Nov 2024 - 21:58
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar thierry83 Dim 10 Nov 2024 - 9:29
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Ven 8 Nov 2024 - 16:55
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Emptypar REYNALD Mar 29 Oct 2024 - 20:18
embrayage feux garde phare galére tenere boue huile selle rabaissement filtre synchro manuel crash réservoir tuto vidange fourche reglage longues pneus essence arrière chaine suis amortisseur
35 €
bnj
bnj
Moto : yamaha xt1200z super ténéré 2012
Kms de ma moto : 29000
Pneu AV/AR : road 4 michelin
Ville ou région : rueil-malmaison
MessageSujet: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 13:43
Bonjour à tous
je continue mes péripéties avec mon XT1200z de 2012
30000kms
après mes ratés moteur, celle-ci cale à la décélération (arrêt stop, arrêt feu rouge etc...)
le voyant ABS s'allume et s'éteint mais le plus souvent reste allumé
le voyant TCS clignote par moment (en ligne droite à 90/110 km/h)
AU SECOURS !!!!!!
https://www.youtube.com/user/TVsceperformance
chmorglube
chmorglube
Moto : XTZ 1200 Supertenere
Kms de ma moto : 42000
Pneu AV/AR : Bridg. A40
Ville ou région : Nuits Saint Georges
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 15:35
controle ton circuit de charge, peut-être alternateur HS..
...Si ça vient de commencer.
Si ça dure depuis plus longtemps, autre cause..
bnj
bnj
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 15:51
les ratés commencent depuis un petit moment mais le reste (calage, ABS, TCS) c'est récent
BNJ
Suivez nous !
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Youtube  GROS GROS PROBLEMES (CALAGE,ABS,TCS) GooglePlus
chmorglube
chmorglube
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 16:54
Ben commence par tester le débit de ton alternateur, j'ai eu ces symptômes sur une autre moto, c'était l'alternateur,
Moto : XTZ 2014 ES
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 19:40
Ou batterie en fin de vie (il faut faire un test complet, pas juste le voltage, qui peut être bon quand la batterie est chargée mais s'écrouler quand elle est sollicitée.
Par contre, ça n'explique pas les ratés je pense mais ils peuvent être éliminés en augmentant le CO.
- Non, mais c’était prévu.
chmorglube
chmorglube
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 21:17
CO et incidents témoins au TdB, j'ai un doute. Circuit de chage et bien sur batterie, mais on peut se tromper..
Faufilé
Faufilé
Moto : XTZ1200
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 18 Juil 2016 - 22:23
Moi j'ai eu une ratatouille comme ça sur ma Deauville, c'était juste la batterie pas assez serrée. Profites en pour enlever les deux caches droits et contrôler, au moins visuellement, que tous les connecteurs de relais sont en place.
Bon courage! les fuck-contact c'est pénibles à résoudre GROS GROS PROBLEMES (CALAGE,ABS,TCS) 730457
Kms de ma moto : laquelle ?
Ville ou région : Besançon
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyMar 19 Juil 2016 - 1:59
contrôle le circuit de charge, ça ne coute rien, mais j'y crois pas trop. .
J'espère qu'il n'y a pas une autre m***e du côté de la rampe ... T'as jamais touché aux by-pass ??
Pour ce qui est de l'abs et du tcs la, joker pour l'instant.
Peux tu aller dans le mode DIAG coupe circuit sur OFF -> d:61 pour aller consulter l'historique des codes pannes. (s'affichent l'un après l'autre si plusieurs codes sont mémorisés)
Ensuite, si tu as des codes pannes mémorisés dans le 61, faire une RAZ -> d:62 et coupe circuit sur ON et a nouveau sur OFF
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyMar 19 Juil 2016 - 2:09
DSL pour le double post, mais j'ai fait un peu d'historique ....
ici -> https://www.super-tenere.org/t11956p50-moteur-brusque#207993
Et ça !!!
mon poto a démonté la rampe et l'a emmené à son atelier.
il a pu sortir la vis en perçant et aussi avec un taro
moralité : 40 euros de pièces et un bon resto !
me voilà sauvé, la synchro a donc été faite. le moteur va un peu mieux mais je vais voir pour acheter la power commander 5 , cela aidera peut être un peu le moteur (j'ai un akra et filtre d'origine)
réglages co à 20
le coups du taraud ça me plait moyen, ça peu dépanner mais ????
---> les réglages de la fameuse vis qui t'as déjà fait iech sont peut être incohérents ....
bnj
bnj
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyMer 20 Juil 2016 - 18:57
hello les costauds
pour ma rampe, je n'avais pas plus de soucis avant qu'après le pb de vis
pour les codes erreurs, 00 en d:61
pour les serrages de cosses, peut etre ça car j'ai branché les feux additionnels le week end dernier
pour la batterie en fin de vie, je ne pense je l'ai changé il n'y a pas si longtemps
Pour le Co , je les avais déjà mis à 20
j'ai un akra, je me demandais si le fait de mettre une power commander n'allait pas arranger la souplesse du moteur
BNJ
Suivez nous !
chmorglube
chmorglube
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyMer 20 Juil 2016 - 19:47
Feux additionnels, donc peut-être un faux contact électrique suite à un mauvais resserrage ou mauvais branchement.
Ou alors, c'est une coïncidence..
bnj
bnj
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptySam 13 Aoû 2016 - 23:43
hello !
me voilà revenu de vacances
a priori, mon souci est résolu, une cosse de batterie était mal serrée.....
merci à tous pour votre aide
BNJ
Suivez nous !
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyDim 14 Aoû 2016 - 1:21
si c 'est que ça tant mieux !! merci pour les news
lacaille
lacaille
Moto : XT1200Z 2011
Kms de ma moto : 45000
Pneu AV/AR : Tourance Next
Ville ou région : Yonne
MessageSujet: Re: GROS GROS PROBLEMES (CALAGE,ABS,TCS)   GROS GROS PROBLEMES (CALAGE,ABS,TCS) EmptyLun 15 Aoû 2016 - 9:39
c'est quand même con, des fois,  une panne...GROS GROS PROBLEMES (CALAGE,ABS,TCS) 49290
GROS GROS PROBLEMES (CALAGE,ABS,TCS) Signat13
» Pneus a crampons gros problèmes
» Problemes ST 750 !
» Problèmes récurrents ??
» Problèmes XTZ 1200 ?
» Problèmes de boîte ?
