Changement joint spi 1200xtz Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Changement joint spi 1200xtz Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Changement joint spi 1200xtz Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Changement joint spi 1200xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Changement joint spi 1200xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Changement joint spi 1200xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Changement joint spi 1200xtz Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Changement joint spi 1200xtz Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Changement joint spi 1200xtz Emptypar Arni Dim 17 Nov 2024 - 14:06
Changement joint spi 1200xtz Emptypar Arni Dim 17 Nov 2024 - 13:13
Changement joint spi 1200xtz Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Changement joint spi 1200xtz Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Changement joint spi 1200xtz Emptypar Fredard Sam 16 Nov 2024 - 9:43
Changement joint spi 1200xtz Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Changement joint spi 1200xtz Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Changement joint spi 1200xtz Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Changement joint spi 1200xtz Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Changement joint spi 1200xtz Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Changement joint spi 1200xtz Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Changement joint spi 1200xtz Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Changement joint spi 1200xtz Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Changement joint spi 1200xtz Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Changement joint spi 1200xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:18
Changement joint spi 1200xtz Emptypar REYNALD Mar 29 Oct 2024 - 20:00
Changement joint spi 1200xtz Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
phare embrayage huile garde filtre synchro amortisseur arrière feux vidange suis longues rabaissement crash réservoir pneus fourche chaine tuto selle manuel essence tenere boue reglage galére
-17%
249 € 299 €
banditos
banditos
Moto : XTZ 1200 World Crosser
Kms de ma moto : 67000
MessageSujet: Changement joint spi 1200xtz   Changement joint spi 1200xtz EmptyDim 8 Mai 2016 - 11:24
Salut à tous,
j'ai une fuite à un joint spi sur ma 1200, je vais essayer de les changer moi-même, y a t il une combine particulière ou un outil spécial, j'ai la revue technique.
Merci.
banditos
banditos
MessageSujet: Re: Changement joint spi 1200xtz   Changement joint spi 1200xtz EmptyVen 13 Mai 2016 - 20:32
Bon, je n'ai pas eu de réponse mais je me suis lancé, largement faisable avec la revue technique, le plus compliqué c'est de compresser le ressort sans l'outil adapté, mais Ok avec une sangle à cliquet mais il faut être 2, c'est plus simple. L'outil pour compresser est réalisable aussi, mais il faut démonter au préalable pour avoir les dimensions.
yannick 63
yannick 63
Moto : 1200 xtz
Ville ou région : puy de dome
MessageSujet: Re: Changement joint spi 1200xtz   Changement joint spi 1200xtz EmptySam 14 Mai 2016 - 8:45
salut vas dans mécanique1200 et ouvre vidange fourche dédé a mis de belles photos. courage.
banditos
banditos
MessageSujet: Re: Changement joint spi 1200xtz   Changement joint spi 1200xtz EmptySam 14 Mai 2016 - 21:05
Merci mais c'est bon, j'ai changé mes joints bien
» Changement joint de cache culbuteur
» Changement joint spi sortie de boîte...
» Changement joint de fourche. Pas de garantie?
» Tuto changement filtre à air et bougies 1200XTZ
» Liste des TUTOS (les produits et liens utiles pour la bricole)
SUPER TENERE XTZ :: SUPER TENERE YAMAHA :: LIENS, BONS PLANS...-
