vidange 600 tenere 90 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
vidange 600 tenere 90 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
vidange 600 tenere 90 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
vidange 600 tenere 90 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
vidange 600 tenere 90 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
vidange 600 tenere 90 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
vidange 600 tenere 90 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
vidange 600 tenere 90 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
vidange 600 tenere 90 Emptypar Arni Dim 17 Nov 2024 - 14:06
vidange 600 tenere 90 Emptypar Arni Dim 17 Nov 2024 - 13:13
vidange 600 tenere 90 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
vidange 600 tenere 90 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
vidange 600 tenere 90 Emptypar Fredard Sam 16 Nov 2024 - 9:43
vidange 600 tenere 90 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
vidange 600 tenere 90 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
vidange 600 tenere 90 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
vidange 600 tenere 90 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
vidange 600 tenere 90 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
vidange 600 tenere 90 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
vidange 600 tenere 90 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
vidange 600 tenere 90 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
vidange 600 tenere 90 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
vidange 600 tenere 90 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
vidange 600 tenere 90 Emptypar REYNALD Mar 29 Oct 2024 - 20:00
vidange 600 tenere 90 Emptypar onemonthoneride Lun 28 Oct 2024 - 11:17
chaine reglage rabaissement phare filtre tuto boue selle synchro arrière garde crash amortisseur huile embrayage réservoir longues pneus manuel galére fourche tenere vidange essence suis feux
-28%
229.99 € 318.99 €
madmax31
madmax31
Moto : tenere 750 xtz
Kms de ma moto : 85200
Ville ou région : frontignan plage
MessageSujet: vidange 600 tenere 90   vidange 600 tenere 90 EmptyLun 2 Nov 2015 - 3:02
Bonjour a tous je cherche un tuto pour vidange moteur boite er filtre huile et air et je rajoute bougie merci a tous
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyLun 2 Nov 2015 - 7:44
https://fr.calameo.com/books/0043604283d4c8ea4077d
vidange 600 tenere 90 Bonett10vidange 600 tenere 90 J_y_yt10
vidange 600 tenere 90 Signat10
Bruno31
Bruno31
Moto : Xtz 1200
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyLun 2 Nov 2015 - 12:12
1/ Huile moteur tiède, comme d'hab
2/ Tu vidanges le bloc moteur (écrou dessous côté pignon), et le cadre (écrou devant en bas). Tu laisses bien égoutter. Après avoir enlever le bouchon jauge.
3/ Tu défais les trois vis du filtre à huile; ça va couler un peu.
4/ Tu remets un filtre neuf et tu ne serres pas comme un âne les 03 écrous.
5/ Tu remets les deux vis de vidange. Pareil tu serres souple.
6/ Tu remplis d'huile (perso 10w50 semi-synthèse). Les 1.5 premiers litres pas de souci. Après faut prendre son temps. Quand tu en as mis 2.5l, tu fermes le bouchon-jauge et tu mets un coup de démarreur, tu laisses tourner 10 s max. Puis tu complètes ton niveau. De mémoire sur l'Xte du fiston 2.9 litres, tu es au maxi.
Pour le filtre à air, pas de particularité. Bougie itoo pas trop fort le serrage.
Sinon, on essaie de ce bloquer un créneau, si tu es dans le secteur.
A+ Bruno
madmax31
madmax31
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyLun 2 Nov 2015 - 14:22
Merci beaucoup bruno c est super sympa je vais me.lancer des que j ai du temps er super fabbuloous vous etes classe merci encore
madmax31
madmax31
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyMer 4 Nov 2015 - 14:57
je galere pour trouver le bouchon de vidange a l'avant cadre en bas? je vois pas suis naze! pour le bloc moteur et filtre pas de soucis mais j'ose pas finir le boulot si y'a une vidange a l'avant !
madmax31
madmax31
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyMer 4 Nov 2015 - 17:04
je viens de comprendre !! j'ai un reservoir d'huile donc pas de vidange a l'avant du cadre mais une seul sous le moteur cote pignon!
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyMer 4 Nov 2015 - 17:39
Salut,normalement le resevoir ce vidange aussi et il me semble sans etre sur qu'il y a une histoire de purge au niveau du filtre a huile,faut desserer legerement une des trois vis et faire tourner le moteur au ralenti pour faire sortir l'air du circuit,a confirmer par les connaisseurs
Salut Michel
vidange 600 tenere 90 8490181200XTZ1
vidange 600 tenere 90 229534038vidange 600 tenere 90 7568070011vidange 600 tenere 90 150151029vidange 600 tenere 90 457366023vidange 600 tenere 90 555053040
MES ALBUMS PHOTOS et MON BLOG
madmax31
madmax31
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyMer 4 Nov 2015 - 18:19
Oui j aimerais en savoir plus
Bruno31
Bruno31
Moto : Xtz 1200
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyMer 4 Nov 2015 - 23:12
Ouep la purge c'est la vis du dessus du filtre.
Tu desserres légèrement attention ça en fout partout, perso, je l'ai fait une seule fois, après aucune purge et no-souci, ça se purge tout seul.
Par contre n'hésite pas, une vidange tous les 5000 km ou une fois par an.
A+ Bruno
madmax31
madmax31
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyJeu 5 Nov 2015 - 2:39
Ok je notes la ou je doutes c est la quantite d huile certain disent.2l d autres 3 j en ai mis 2,5l et je vais reverifier aujourd'hui autre question la bougie c est pas galere? Car vu l acces! Je vais faire le filtre a air et ensuite noter tout ça
Bruno31
Bruno31
Moto : Xtz 1200
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyJeu 5 Nov 2015 - 11:31
pour l'Xte 600 du fiston je confirme 2.9l maxi. pour ton moteur vois dans le manuel mais je pense que 2.5 c'est bon.
Pour la bougie toujours sur l'Xte accès facile, mais pour le tien, peut-être que la pose du réservoir facilitera la manip, mais normalement c'est jouable...galère pour les grosses mains  Smile
bonne continuation.
Bruno31
Bruno31
Moto : Xtz 1200
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyJeu 5 Nov 2015 - 11:33
Ah au fait il y a ce site, pas mal d'info
http://600xt.bbfr.net
marco
marco
Moto : XT 600 et 1100 gs
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyDim 8 Nov 2015 - 17:55
le 600 XTZ ,n'a absoluement rien à voir avec le XTE
 tu peux chercher un moment les bouchons devant ,y'en n'a pas clin d\'oeil
marco
marco
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyDim 8 Nov 2015 - 18:20
 eh si  ,il faut vidanger le reservoir et le point sous le moteur
 je viens de t'envoyer la doc en MP
marco
marco
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyDim 8 Nov 2015 - 18:21
Salut Michel
exact aussi   ,la vis du dessus  , mais ça c'est quand tu as rempli motard
Lobster Johnson
Lobster Johnson
Moto : Ténéré 3AJ
Kms de ma moto : 51000
MessageSujet: Re: vidange 600 tenere 90   vidange 600 tenere 90 EmptyVen 19 Aoû 2016 - 13:18
Salut à tous,
    Je déterre un peu ce sujet. Je suis en train de faire am vidange sur ma 600 en vue du HAT 2016 et un truc m'a choqué: sur la connexion du réservoir d'huile je n'avais pas de joint torique sur ma crépine. J'en avais un sur chaque vis (entre le raccord et le réservoir et des petites rondelles sous les têtes de vis) mais rien sur la crépine alors que les catalogues ( http://www.pieces-yam.com/yamaha-pieces-catalogue-11016-6.html celui qui me manque est ne N° 27) et la RMT mentionnent bien un torique partout (outre le fait que mécaniquement ça parait logique).
Autre truc qui me choque: la crépine en elle même. Elles ont la même tronche les vôtres ?
vidange 600 tenere 90 20160819_123142_zpsxvijrtvt
vidange 600 tenere 90 20160819_122623_zpszgejpl4o
» XTZ660Z Ténéré Vidange:Comment faire.....
» révision 10000
» vidange XTZ
» Vidange xte
» vis de vidange
SUPER TENERE XTZ :: PRÉSENTATION MÉCANIQUE ACCESSOIRES DES XTZ :: 600 XT TENERE ( de 1983 à 1990) [34L - 1vj - 3AJ] :: MECANIQUE-
