Branchement Gps Garmin 350 Emptypar oeuf Aujourd'hui à 10:11
Branchement Gps Garmin 350 Emptypar oeuf Aujourd'hui à 10:03
Branchement Gps Garmin 350 Emptypar SuperTiti Mer 20 Nov 2024 - 21:40
Branchement Gps Garmin 350 Emptypar Joe644 Mer 20 Nov 2024 - 18:56
Branchement Gps Garmin 350 Emptypar yop1025 Mer 20 Nov 2024 - 13:10
Branchement Gps Garmin 350 Emptypar REYNALD Mar 19 Nov 2024 - 10:58
Branchement Gps Garmin 350 Emptypar REYNALD Mar 19 Nov 2024 - 10:49
Branchement Gps Garmin 350 Emptypar REYNALD Mar 19 Nov 2024 - 10:46
Branchement Gps Garmin 350 Emptypar REYNALD Mar 19 Nov 2024 - 10:44
Branchement Gps Garmin 350 Emptypar jackal74 Lun 18 Nov 2024 - 11:58
Branchement Gps Garmin 350 Emptypar Arni Dim 17 Nov 2024 - 14:06
Branchement Gps Garmin 350 Emptypar Arni Dim 17 Nov 2024 - 13:13
Branchement Gps Garmin 350 Emptypar Kcenobait Dim 17 Nov 2024 - 5:33
Branchement Gps Garmin 350 Emptypar yop1025 Sam 16 Nov 2024 - 23:12
Branchement Gps Garmin 350 Emptypar Fredard Sam 16 Nov 2024 - 9:43
Branchement Gps Garmin 350 Emptypar FoggyRider Mar 12 Nov 2024 - 20:04
Branchement Gps Garmin 350 Emptypar J-Marc Mar 12 Nov 2024 - 12:44
Branchement Gps Garmin 350 Emptypar J-Marc Lun 11 Nov 2024 - 21:58
Branchement Gps Garmin 350 Emptypar BtitziaBZH Lun 11 Nov 2024 - 8:25
Branchement Gps Garmin 350 Emptypar tenerefazer Dim 10 Nov 2024 - 16:35
Branchement Gps Garmin 350 Emptypar thierry83 Dim 10 Nov 2024 - 9:29
Branchement Gps Garmin 350 Emptypar REYNALD Ven 8 Nov 2024 - 16:55
Branchement Gps Garmin 350 Emptypar onemonthoneride Dim 3 Nov 2024 - 20:20
Branchement Gps Garmin 350 Emptypar 40390Denis Mer 30 Oct 2024 - 18:10
Branchement Gps Garmin 350 Emptypar REYNALD Mar 29 Oct 2024 - 20:18
crash garde filtre huile reglage tenere rabaissement amortisseur manuel feux fourche tuto selle vidange réservoir chaine arrière galére essence longues pneus embrayage suis synchro phare boue
Le Deal du moment : -29%
269.99 €
aigle74
aigle74
Moto : :st 1200 bleu
Kms de ma moto : 31100
Ville ou région : rhone alpes,bas chablais
MessageSujet: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMar 3 Mar 2015 - 19:01
Salut à tous! j'ai un petit problème de branchement sur mon gps Garmin 350lm,j'ai fait branché le cable d'alimentation sur un plus  après contact .Dans la fiche qui ce trouve dans le support, il y a du courant environ 5 ampères le mécano la mesuré devant moi,car je suis une quiche en élèctricité moto!! bon bref et quand je fixe le gps sur son support, il ne se charge pas!donc pensent que les deux broches derrière le gps ne faisaient pas contact correctement, j'ai sortie la prise du support gps, pour la plaquée correctement sur les connections plates derrière le gps,contact allumé rien pas de charge,et moteur tournant pas plus de chargement??Est ce que quelqu'un aurais une idée de ce qu'il ce passe,j'ai contacté le mécano qui ma installé la connectique il ne comprend pas non plus. Au secours!!
Pneu AV/AR : Road 5
Ville ou région : Le douze
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMar 3 Mar 2015 - 20:51
Heuuu, J'ai bien une idée mais je sais pas si je peux ???
je suis une quiche en électricité moto!!"... Moi aussi, c'est pas grave, c'est pour ça qu'on paye des mécanos pour faire le taf  Branchement Gps Garmin 350 492970
Par contre, "Mon mécano est une quiche lui aussi"....   Branchement Gps Garmin 350 49290
aigle74
aigle74
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMar 3 Mar 2015 - 21:03
alors personne pour m'aidé!please
Pneu AV/AR : Road 5
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMar 3 Mar 2015 - 21:31
Le courant arrive (t'es sur?) mais le GPS ne charge pas.
La connectique de ton GPS est HS ou alors c'est ton GPS lui même qui est HS (Batterie qui ne prend plus la charge)
Essaye de le charger sur une autre source (chargeur domestique, voiture...)
Attention, les GPS inutilisés depuis longtemps peuvent ne rien afficher sur l'écran avant d'être rechargés un minimum.
Sur mon Garmin Zumo, il y a une petite diode verte sur le dessus pour attester qu'il est en charge, même si l'écran ne s'allume pas.
Faut juste attendre quelques minutes.
S'il ne charge toujours pas, faudra changer sa batterie... ou changer de GPS
S'il charge sur un chargeur domestique ou sur la voiture, c'est que le courant n'arrive pas sur ta prise moto, non ?
Et donc, retour à la case départ (chez le mécano...)
Domi1663
Domi1663
Moto : Tracer 9 GT
Kms de ma moto : 6500
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMar 3 Mar 2015 - 23:32
Tester déjà la charge sur une voiture ou sur secteur ou PC.
J'ai installé le mien récemment, en récupérant le plus après contact sous le flan droit du réservoir, voir posts sur ce sujet et tout fonctionne correctement. D'ailleurs j'ai un Zumo 210 et je ne suis pas obligé de mettre la batterie quand je fonctionne en branchement direct sur la moto. La différence c'est que sans batterie, forcémnet, dès que je coupe le contact, l'appareil s'éteint (normal). Sinon avec la batterie, il annonce qu'il passe en mode batterie et demande si on veut l'éteindre ou pas.
aigle74
aigle74
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 18:37
Alors le gps ce charge sur la prise secteur, sur le pc, et sur la prise 12 v voiture, j' ai un métrix mais je n'y comprend rien!je me demande si les deux picots plats derrière le gps qui fond la connection avec la prise dans le support,ne sont pas d'effectueux!! Branchement Gps Garmin 350 2107
jean-pierre 74
jean-pierre 74
Kms de ma moto : 82 000
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 19:00
Le Tomtom rider 1 a eu lui aussi à sa sortie des problèmes de charge dû aux picots de son support moto qui ne faisaient pas contact.
En juin, j'ai racheté un nouveau Rider, et j'ai été obligé de faire changer 2 fois en garantie le support moto qui ne marchait pas.
Si ton zumo charge correctement avec d'autres supports que le support moto c'est probablement lui qui est en cause. Voir avec le sav si toujours sous garantie.
Il serait intéressant de mettre ton GPS sur une autre moto que la tienne pour voir s'il fonctionne correctement..
aigle74
aigle74
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 19:22
donc pour toi c'est la connectique entière celle avec le boitier et le fusible qui serait en cause, enfin si je t'es bien compris!!en tous cas merci à tous pour vos idées, et avis!!!
jean-pierre 74
jean-pierre 74
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 19:57
Oui je parle du support sur lequel tu accroches le gps, là ou arrivent tes fils après le +.
Kms de ma moto : 140000
Pneu AV/AR : SCORPION
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 20:39
Si tu positionnes ton metrix sur V=, et que tu testes les deux picots coté support avec le contact sur la moto, tu devrais avoir +12 (ou -12 ) environ, si tu n'as rien c'est que le support ne laisse pas passer le courant. Tu peux démonter la prise et faire la même opération pour voir si le courant arrive jusque là.
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyMer 4 Mar 2015 - 21:16
Et si tu le branchais en live sur la batterie et avec sur le fil R en sécu un fusible 10 A  bien
Branchement Gps Garmin 350 Ct2rou14Branchement Gps Garmin 350 Logo_y12Branchement Gps Garmin 350 Vosges11 Branchement Gps Garmin 350 J_y_yt11  Branchement Gps Garmin 350 J_y_yt10
aigle74
aigle74
MessageSujet: Re: Branchement Gps Garmin 350   Branchement Gps Garmin 350 EmptyJeu 5 Mar 2015 - 20:14
BON y a rien qui fonctionne! j'ai contacté le sav du site d'achat,il mon répondu rapidement qu'il faut tout leur renvoyé ,gps, connectique,les cables enfin tout pour l'envoyé chez le fabricant pour le soumettre a expertise,test bla,bla, alors je m'y emploi et je vous tiens au COURANT marrant je jeu de mot, mais ca risque de prendre du temps!voilà bonne soirée.....
» garmin 550
» qui a un Garmin nüvi 510 ?
» Garmin Zumo 660
» GPS garmin zumo 290 LM
» garmin gpsmap 62s
